3 way fuel petcock
JD keith
05-10-2005 09:03:59
ok guys i have a 45 B I turned the 3 way control valve several times , and now i dont know which way is for the auxillary tank and which way is the main tank or shut off all together . Is there any one amongst us that can tell me how to set this thing back to it's rightful setting ????
Thanks
JD Keith
05-11-2005 06:34:21
 Re: 3 way fuel petcock in reply to JD keith, 05-10-2005 09:03:59
Ok guys , last night i tried at it again. I tried to blow into the line back thru the valve, i could blow into the reserve tank , but i never got a darn thing , by trying to blow into the main tank, which leads me to believe, that could be a reason i couldn't figure it out , possibly the main tank is plugged up with debri??? any way later this week , when I have the time i'm going to fill the reserve tank up and try to get it the 2 miles from storage to my home and there i can investigate further, thanks for your replys.
Keith
Bobl1958
05-10-2005 11:09:46
I don't know for sure how to tell if it is on the tractor except to let a little fuel run out into a can to see where it is at. If it is off you would probably be able to tell by blowing in it or something like that.
old
05-10-2005 10:24:42
If its like the one on my 1935 B it will be pointing to the rad. the big tank pointing to the seat little tank and down off.
D-GEEK
05-11-2005 09:43:47
 Re: 3 way fuel petcock in reply to old, 05-10-2005 10:24:42
On my 35D 3-Way it's stamped O,K,G, right on the brass of the valve. O to the front, K to the back,
and G down. I assume these stand for off, kero
and gas. To be honest I've been tore down for
5 months and can't remember which way it worked
for me and I found the markings this winter when
I was cleaning it up. I will know soon though
as I plan to have her running this weekend. I
will post my finding as soon as I can.
Good Luck DG
jd keith
05-13-2005 10:20:31
 Re: 3 way fuel petcock in reply to D-GEEK, 05-11-2005 09:43:47
Thanks DG gonna work on it tonight , and look for the markings. I appreciate the input , I'll let you knnow how it goes.
Keith
D-GEEK
05-11-2005 09:41:56
Good Luck DG
