JD 8200 update
agri_con
05-10-2005 03:34:58
Posting this for future reference to some that own 8000 series tractors.The original complaint was at the remotes #1 scv wouldn't hold a load,after determining it was only based in that single remote,began the task of troubleshooting.Step by step from the tech manual and even help from some on this site,the local dealership,even DTAC,some springs were changed,new seals-due to valve being completely removed for inspection.changed the couplers due to leakage.After reassembly the problem became more complex with one side(coupler) become slow with adjustments set at max yet would slow down when set.Once again I tore into this valve and after going thru the hyd schematic found that inside the load checks is an unservicable check valve blown apart.No mention of this what so ever in a tech manual.Thankfully it was on the side you can get to without removing the valve.With all this said I'll add my addition to the tech manual-upon load check dissassembly-mildly shake the cartridge-if it rattles around and ya you can see thru the holes peices moving-JUNK IT
