Deluxe Fenders 30 Series and 20 Series?
JDVan
05-10-2005 00:51:10
Are the Deluxe fenders that were an option on the 530 to 730's an appropriate install option on the 20 series as well? The Parts Catalog only references the 30 Series. It is my understanding these fenders were first announced as an option when the 30 series came out but I have seen them installed on 20 Series. Did JD encourage this or is this just enterprising individuals who have done so. I don't see a wiring loom specifically for the 20 series either. Also is there anyone producing reproduction lights and wiring for these deluxe fenders? Thanks
James2
05-10-2005 09:49:54
 Re: Deluxe Fenders 30 Series and 20 Series? in reply to JDVan, 05-10-2005 00:51:10
I think it is OK if you are going to use the tractor at "home". I would not want to take the tractor with incorrect fenders to a show or parade. Personally, unless I required the added protection of the 30 series fenders for passengers, or did a lot of after dark work, I would put on the correct fenders which in my opinion look pretty good.
buickanddeere
05-10-2005 08:24:58
As long as the proud owner of the 70 with flat top fenders and a yellow stripe paint job. Doesn't stand there with a stright face and a sincere belief that Pappy ordered it that way from the factory. An incorrect restoration can send an amature who is trying to be correct on his own project, a bum steer.
tractordave
05-10-2005 11:26:50
 Re: Deluxe Fenders 30 Series and 20 Series? in reply to buickanddeere, 05-10-2005 08:24:58
True 'nuff. I suppose that I should add a disclaimer to my previous statement, that if you do choose to have a 70 with flat tops and yellow stripe that is fine as long as you do not misrepresent the tractor. Claiming something is original when it is not can hinder the hobby.
Dave
720Deere
05-10-2005 05:57:45
They may not be deemed appropriate, but they look darn good on a 70 diesel also! They could be considered a factory retrofit for the 20 series. After all, Deere sells quite a few products targeting the New Generation tractors that would not be considered correct by the "police", but nonetheless, they are sold by the OEM and Deere dealers. Your deluxe fenders would fall under the same. I'm sure that dealers encouraged their use on 20 series as every accessory sale covered just a little bit more of their overhead that year.
Indydirtfarmer
05-10-2005 04:05:08
The "Correct-ness Police" will be pounding on your door by daybreak.....
They weren't "released" by Deere until the 30 series, but if you want them on your tractor, go for it...
If you're trying for an accurate restoration, no, they don't belong there.
If you're USING that 20 series tractor, and want the saftey/security of a well designed set of fenders, you could do no better.
No one says they ALL have to be museum accurate restorations.
Back in the day, farmers made subtle improvments to their field tractors as they wanted/needed to. By the early 60's there were a BUNCH of 20 series tractors sporting 30 series fenders. They might not be original, but they weren't that uncommon either....
tractordave
05-10-2005 07:31:49
 Re: Deluxe Fenders 30 Series and 20 Series? in reply to Indydirtfarmer, 05-10-2005 04:05:08
Just my opinion... this hobby is about preserving farm history as much as preserving old JD tractors. Some of that history is farmer modifications! If a farmer put 30 series fenders on his 720, or painted his 70 with the yellow introduced on the 20 series, well then yes, I personally believe it is QUITE legit to restore a tractor that way.
Just an opinion, take it for what you will!
Dave
Indydirtfarmer
05-10-2005 10:26:00
 Re: Deluxe Fenders 30 Series and 20 Series? in reply to tractordave, 05-10-2005 07:31:49
Almost threw me for a loop there! I'm in complete agreement. Also, who says because ONE PERSON wants a pristeen, concours grade restoration, that the NEXT person has to "play by those rules". Not all of us are into the full-blown museum quality restorations on every tractor we work on. Some are for USING, and need to be USABLE as we see fit.
I have 2 tractors that are resored right down to the correct wire insulation, radiator hose clamps, brand of radiator cap, ect.... Then I have a couple that show a few "improvements" as needed to be working members of the fleet.
It's all about what a person wants. I don't make the rules for YOUR tractor, and don't expect you to make the rules for mine.....
I Bleed Green
05-10-2005 03:26:39
I also see them put on 20 series. I do not think they are appropriate.
