Can I Install A Modern Thermostat In Early JD60?
StuckRusty
05-09-2005 20:22:02
Some posts back there was a discussion on using an automotive type thermostat to replace the shutter system in an early JD50. My JD60 shutters are long gone and I would like to install a regular thermostat too. If it can be done, where would one fit?
John Van Valkenburgh
05-10-2005 17:08:09
 Re: Can I Install A Modern Thermostat In Early JD6 in reply to StuckRusty, 05-09-2005 20:22:02
I've thought about trying to do this on my 50. The conclusion I came to was that the easiest route would be to retrofit the later castings to the tractor. If you were to put a thermostat in-line you will need to add some sort of pressure relief that is active when the thermostat is closed. The later systems have a little bypass hose that does this.
What I ended up doing is buying an old set of shutters in good condition and making a manual control to open and close them. I keep them closed until the tractor gets up to around 200 degrees and then I'll open them up. Not the ideal solution but it works okay as long as you keep your eye on the temp with the shutters closed.
I've found that there are times especially in the winter when I never open the shutters at all. There is something like 6 or 7 gallons of coolant in my system that has to heat up to 200 degrees and that takes a lot of time.
John
1953 Model 50
JDVan
05-09-2005 21:08:59
It can be done but you will need to find a later parts 60 that has all the different parts on it to accomodate the thermostat setup. There may be a way to cobble one up but I haven't done that. The parts differences are clearly shown in the Parts Catalog.
