720LP.WHAT THE HECK CAN IT BE?
Ben.So.Tex
05-09-2005 20:01:25
I rebuilt the engine. But it has a tappining soung like it is coming from the valve setting I have check the clearance at 20 hot .cold. while it is running. moveds the timming while running.. rechecked the insert cap at 80# per the book The only thing that I have not done it to recheck with the machine shop that redid the head and and see if they lapped the valve in ..NOW ONE of the wrist pins had a slight blue tent to it, like it may of got hot some time,, But I don't think that is the problem.. That will be the last thing for me to replace. The noise has seem to quiten down a little. I plan on putting a chisles plow to it later to see if the work will shut it up.. Cam gear good lifter good.. Ben
Mike M
05-10-2005 03:48:32
 Re: 720LP.WHAT THE HECK CAN IT BE? in reply to Ben.So.Tex, 05-09-2005 20:01:25
Did you reface the rocker arm tips ? They could be worn causing a false clearance reading. On some models of JD's (late B's for sure)noisy valve trains are normal.Can't say for sure on 720 gas engines not many around to listen to.
Jake
05-10-2005 15:57:31
 Re: Late B valve train noise?? in reply to Mike M, 05-10-2005 03:48:32
Mike,
Do you know why the late B"s have noisy valve trains? My 1950 B is very noisy too. Klickety klackety all the time. When I bought the tractor I found the valve lash set at ZERO and it was even noisy then too. I have ran it with the valve cover off and even shutting off the engine and watching it coast to a stop there is a very pronounced clicking deep inside someplace right till the very last movement and slow rotation of the crankshaft.
Mike M
05-10-2005 18:42:04
 Re: Late B valve train noise?? in reply to Jake, 05-10-2005 15:57:31
I have determined that it is the nature of the beast. Just make sure everything is fine,rocker arms smooth,adjust per book,shim up any extra side play in the rockers. That noise just adds to the charm of them and as long as you can hear them you know there still working.
Jake
05-10-2005 21:39:09
 Re: Late B valve train noise?? in reply to Mike M, 05-10-2005 18:42:04
Well, some day I will do an overhaul and restoration of it and then I can search for the source of the klackity klack sound and see if there may be a solution.
Ben.So.Tex
05-10-2005 04:04:07
 Re: 720LP.WHAT THE HECK CAN IT BE? in reply to Mike M, 05-10-2005 03:48:32
Thanks Mike. I have check them and they are smooth as baby skin.
CARL SCHMIDT
05-12-2005 18:49:43
 Re: 720LP.WHAT THE HECK CAN IT BE? in reply to Ben.So.Tex, 05-10-2005 04:04:07
Sorry to change the subject but what would be the value of 720LP narrow front with a single front tire, complete 3point, pto, dual hydraulics, power steering, new tires,no fenders ? Anyone know how many of these were built?
