JD 4000 vs 4010/4020
Peter Carlson
05-09-2005 13:07:27
Why did JD make the 4000? I understand it is lighter then a 4020, but I do not know why. What was left off to make it lighter?
Since there were relatively few made,,, Is it considered a collectable tractor?
Thank you.
buickanddeere
05-10-2005 11:52:16
 Re: JD 4000 vs 4010/4020 in reply to Peter Carlson, 05-09-2005 13:07:27
What you should be asking is 4010 Vs. 4000/4020.
ET
05-10-2005 07:46:12
The 4000 was rated at 96hp so it had a little more juice than a 4020. There is no syncronizer on reverse in a 4000.
msb
05-09-2005 22:07:30
A lot of good observations but the bottom line was the 4000 was $800 cheaper that the 4020 and $800 was a lot more money back then than it is today.
infogatherer
05-09-2005 18:41:09
A 4000 was basicially a custom 4020. Like in the car and truck world a custom is a vehicle with few opitons, and cheaper, and the 4000 was just that. It was a direct competitor of the IH 856 custom. IH sold some 856 customs im not sure of the exact number. John Deere came out with the 4000 shortly after the 856 custom. There werent as many 4000's as 856's. The 4000 is an uncommon tractor to find today.
Bob N.Y.
05-09-2005 18:25:01
The way I remember it, International came out with a stripped down 856 that they called the 826. They advertised it as costing less than the 4020. John Deere responded with the 4000 at a competitive price.
JDJim
05-09-2005 18:23:50
The 4000 is always getting a bad rap. JD had to compete with IH and the 4020 was a very profitable machine for JD so instead of discount the 4020 the 4000 was created. JD did not want the buying public to know that they could produce the same tractor for less money. The components are exactly the same other than the axles and a few other very minor things. 4020 had 3 3/8 and 4000 has 3 1/8 which is the same as 3020. Horsepower is the same as they both use the same 404 engine. 4000 only came in side console and as so few were made compared to 4020 I feel they are very collectable. I have a 72 4000 with 5200 hours on it that dynoed 115 hp with pump turned up and will go head to head with any 4020. If it is clean and well kept buy it because it will be a lot less than a 4020 and a way better machine than a 4010.
gpop
05-09-2005 17:59:16
john deere built these as a race horse 3020,their ads runs as trade your 3020 off for a4000 and keep your same implements and go faster ,doing the same jobs in the fields,3020 axles etc were used,plus a 12volt electric system,
j cook (iowa)
05-09-2005 17:29:07
In 1969, John deere really needed a 6 cylinder 3020. Something with MORE hp than the 71hp 3020 and CHEAPER than the 95hp 4020, which could compete in the 80hp class! The two available engines, the 6329 and the 6404. Unfortunately, the 6329 cost MORE to produce than did the 6404 (aka 4020 engine). Rather than detune the 404, the just reduced the specifications on the rest of the tractor. They are collectable!
Peter Carlson
05-09-2005 18:14:58
 Re: JD 4000 vs 4010/4020 in reply to j cook (iowa), 05-09-2005 17:29:07
Ahh,, interesting,, makes perfect sense form a marketing standpoint,,, but apparently not to the consumer though.
What was the 6329 used in?
Thank you
Chris(Pa)
05-09-2005 17:03:27
The JD 4000 was designed to have more power than a 3010 or 3020 but still be able to use the same implements. This saved the farmer who needed more power but didn"t have enough money to buy new implements. I would think it would be lighter than a 4020 because it has less power and was designed to use a 3020"s implements so it wouldn"t need to be as strong and it would have less steel. This would be a rare tractor since so few were made.
Gerald J.
05-09-2005 13:22:52
The 4000 may be heavier than a 4010. But its lighter than a 4020 due to less steel in the transmission and axles, less trim (no cover for the rock shaft valve, no battery boxes, no tool box under the seat... The axles are smaller, and so too some of the drive train parts.
It sold for less and that's what kept it made for its short lifetime.
Gerald J.
