620 Switch
onefarmer
05-09-2005 11:41:09
What is the differance between the switch on a 630 vs a 620? I have a chance to get a 630 sw for less than the 620, but want it to work currectly. I have a 620 that won't power the Ign. The lights work ok though. I currently use a toggle sw for ign, but want to put it back on the main sw.
John T
05-09-2005 12:40:37
 Re: 620 Switch in reply to onefarmer, 05-09-2005 11:41:09
One Farmer, that 620 switch is more complicated n has more contacts since the 630 uses a push to start switch, starter solenoid, and dont have the MAG terminal to kill the ignition when cranking etc.
On the 620 switch does the IGN terminal not get hot n stay hot in any of the ON switch positions or what???? Im sure its possible to jury rig the lights to make either switch perform basic functions, but they dont seem compatible to work like a factory original set up with the wrong switch from what im looking at for now.
The 630 switch still has a BAT input and an IGN output (to coil and ballast) and some light contacts so it could be made to work Im sure, but that 620 uses a ballast by pass circuit fed up from the mechanical starter switch while the 630 by passes via the push to start switch and it uses a starter solenoid you know.
This is one of those things if there I could wire it somehow n get most to work except for killing the ignition when cranking if the ignition is off (the MAG terminal) but hard to describe over the net.
Sooooo o the switches are different but it can be jury rigged to work (mostly) if you know what youre doing I reckon.
John T
onefarmer
05-09-2005 15:49:14
 Re: 620 Switch in reply to John T, 05-09-2005 12:40:37
Sounds like the only main differance is the Mag terminal? On my current switch the IGN terminal is completely dead at all times. Most likely the contacts are worn off inside. Been like this for 20+ years. I just inhereted it from my father who passed away last Jan. The 620 is what I grew up on and the first tractor I ever drove. We worked many acres together till we got a 720 and then a 4320. While I'm mostly color blind when it comes to tractor brands I've used JD MH MF IH there is nothing like you first tractor and that 2cyl JD sound.
