6030 Smoke
Howard H.
05-09-2005 07:41:31
Hi Ya"ll -
My 6030 runs good, sounds good, etc, but on start up and after idling a while and then revving it on up, it smokes a noticeable amount...
It is pale blue - almost white - and extra-dieselly smelling...
It doesn"t use oil. It isn"t using water and doesn"t heat, so I"m not too worried about a head gasket or anything.
I suspect (or hope) it might be the injectors or fuel pump.
It has about 8000 hours on it.
What would be the most likely problem? Any way to diagnose it for sure??
Thanks a lot,
Howard H.
thejdman01
05-09-2005 15:14:00
 Re: 6030 Smoke in reply to Howard H., 05-09-2005 07:41:31
back to the basics. white smoke on a diesel unburnt fuel due to lack of heat. blue burning oil. black u nburnt fuel due to lack of air. (whether pump turned up restriction in air cleaner wahtever. white smoke with a touch of blue means its burning oil. its got 8000 hours could be a little rings a little valve guides a little here a littler there its adding up making it smoke blue. with that many hours on it if it doesnt use it excessivly and doesnt bother you run it. dont worry about it. all diesels will smoke white when cold not enough heat to burn the diesel. as said if the pumps turned up will be noticable more then a stock one. these new diesels have cold weather compensators change timing delivery etc when cold but for an old engine like yours white smoke is nothing alarming. if it isnt bothering you dont worry about it(the blue smoke) the white smoke you wont get rid of even if you rebuild the entire motor fuel system will still smoke white when cold not as much but still will. best thing to do is plug it in if your in a cold climate let it warm up bought 2 minutes and work it. i wouldnt mess with it.
G/MAN
05-09-2005 15:53:19
 Re: 6030 Smoke in reply to thejdman01, 05-09-2005 15:14:00
With an engine and fuel system in good condition and properly timed and calibrated, any smoke at idle should be minimal. Even with a "cold" engine, there should be sufficient compression and therefore heat to do a good job of burning the very small amount of fuel needed to operate a diesel at idle. You'll only get black smoke due to unburned fuel when the engine is under load or is accelerating. Also, cranking up the fuel delivery on a pump usually only increases the MAXIMUM amount of fuel the engine can get when under load, by allowing the rack to travel farther. Turning up the fuel delivery should have very little effect on the amount of fuel being delivered at idle speeds. As I said, the worn plungers and barrels and governor components that usually go along with an engine that has a lot of hours and may have been "tuned" contribute a bunch to throwing off the pump calibration and fuel delivery, and can do so at all operating speeds. Pulling the nozzles for testing and checking the compression can be done for next to nothing in terms of parts $$$, and is the ONLY way to determine what is actually causing the smoke.
James2
05-09-2005 12:37:00
That sure is a lot of hours. Does it start fairly good at low temperatures? If it starts poorly, I would suspect low compression and the fuel is not getting completely burned unless you load it up. If it starts ok, I would look at the nozzles and/or pump. With that many of hours the nozzle orifices have significant wear which would effect fuel atomization and burn quality at light loads. Surprising, larger fuel droplets don't effect cold start much (within a reasonable range that is). In fact if you atomize the fuel too much, it acts similar to gasoline and cools the combustion chamber resulting in worse starting. I'm sure nozzle VOP (valve opening pressure) is also down at this high hour level. If I were to guess, probably both (fuel system and compression) are contributing to the problem. You can want, but can't expect an engine to run at optimum forever.
Glen in TX
05-09-2005 11:49:54
Sounds normal. Probably had the pump turned up some too. Get yourself a tech manual and shop for a mechanic that knows that engine and not the new local dealer guy so you'll be ready later. It's going to need checking out soon or later with that many hours if it hasn't been done recently. Drop a rod on that one and get ready to spend $$$$$. Thats why the 619 gets put in later. Most mechanics today haven't even seen a 6030 let alone touched one.
G/MAN
05-09-2005 16:00:20
 Re: 6030 Smoke in reply to Glen in TX, 05-09-2005 11:49:54
Were I working over a 6030 for normal field service, I'd skip the actual "6619" engines and jump right to the last 500-series engines Deere built, the 6101. Still 619 cubes, and maybe a little more work to retrofit into a 6030, but you'd have the latest and greatest engine of that size Deere built prior to moving to the 6105 and 6125 for their high-horsepower engines. Were money no object and if I simply wanted the baddest "field" 6030 around, I'd do whatever was necessary to slap in a 6125. Can you imagine a 6030 screaming through the field with a 400+ hp, 4-valve, unit-injected, overhead-cam, electronically-controlled, air-to-air aftercooled, all-Deere monster like that under the hood? Tim the Toolman would be proud.
Glen in TX
05-09-2005 16:49:14
 Re: 6030 Smoke in reply to G/MAN, 05-09-2005 16:00:20
OK G/MAN or Tim? LOL. I've ran a 6030 a lot of hours more than is on this guys and NO WAY would I spend that kind of money with that dust eating loud cab on a 6030. I'd spend it on something with a lot better cab and seat for sure. Most guys that turned up 619s in 6030s done toasted the trans anyway. A rebuilt 619 or a good used one is lots cheaper than a major overhaul on a 531 most times. But...if money were no object....
G/MAN
05-10-2005 07:35:57
 Re: 6030 Smoke in reply to Glen in TX, 05-09-2005 16:49:14
If money were no object, a Sound-Gard off of a 50-series would be a definite addition, such as on Kinze's "5050".
Glen in TX
05-10-2005 08:25:14
 Re: 6030 Smoke in reply to G/MAN, 05-10-2005 07:35:57
Yeah, that has been done too. There was some pics of a 6030 in Farm Show magazine years ago of one a guy did in Canada. I don't know if they have that in their archives or not?
G/MAN
05-09-2005 10:42:31
It may be relatively normal for an older tractor with some hours, but it's definitely not a situation you want. Excess fuel can wash down the cylinder walls and lead to faster wear of the sleeves and rings. That smoke is also simply wasted fuel, and seeing as how that 6030 is probably already thirst enough and farm diesel isn't getting any cheaper, getting it fixed could save you some coin long-term. I'd pull the nozzles and test them. Warm the engine well before pulling the nozzles and check the compression after removing them. And check the timing. You could also send the pump in to be checked and recalibrated or rebuilt. Worn plungers and barrels can overfuel an engine. That won't be a cheap fix. You just have to weigh how you want it to operate against what you want to spend to make it right.
CMB
05-09-2005 08:55:23
Doesn"t sound like a real problem to me, as my 7520 (same engine) does that too. Probably a matter of it getting quite a few hours,& the compression pressure isn"t as high as it was when newer, especially when idling. I"d also bet that the fuel delivery has been "turned up" at some point in the past, which would tend to make this situation worse.
billyiron
05-09-2005 08:03:25
I think thats pretty normal,,ours does the same thing, also the 4520 too,,they tend to load up when they idle,,,billy
