630 Overheating
Greg A
05-09-2005 05:11:29
I was disking on Saturday (8' tandem disk), within 15 minutes the tempature gauge rose to +200 degrees and there seemed to be pressure building up in the fuel tank. We have had this tractor for several years and I don't recall the temp ever rising above 180 before. I am suspecting a faulty thermostate but wondering if there is other problems that may make the tractor overheat, and also wondering where exactly is the thermostate located and what is the procedure for replacing it.
Mike M
05-09-2005 09:45:45
 Re: 630 Overheating in reply to Greg A, 05-09-2005 05:11:29
When you get it drained and the top pipe off to get at the thermostat I'd go ahead and back flush out the radiator. Put your hose in the bottom and flush up to the top letting the crap flow out of the top where the thermostat sets.I did one for my uncle a few years back, we had to stick a air hose nozzle in the bottom with the garden hose to add some more pressure to blow out the junk.
old
05-09-2005 06:20:57
Could be a couple things a thremo is a good place to start. Also a good flushing out of the rad wouldn't hurt either. I flush them with vinegar fill it up with vinegar and run it for a little to get it hot then let it cool and flush it with water
buickanddeere
05-09-2005 06:15:31
1-800-522-7448 with serial number and credit card in hand.
