JD 2640 hydraulics problem
Willy P
05-08-2005 19:42:57
On my old style JD 2640,when I use the pto like mowing or something,I loose the hydraulics. The steering and brakes work but the remotes will not work acts like it is starving for oil,could someone give me some advice on where to begin diagnosing the problem? Thanks
Cory R.
05-10-2005 08:13:38
 Re: JD 2640 hydraulics problem in reply to Willy P, 05-08-2005 19:42:57
The 2630 john deere we have at home does the same thing you have to run the throttle wide open when warm to get the pump to work. The John Deere Mechanics said there notin you can do about it the 2630 and 40 tractors are junk in that way. John Deere needed to revamp the hydrolics but didnt on that series of tractors. I guess you will have to live with it we do.
Tx Jim
05-09-2005 04:07:12
Willy,if it has ind.pto/lever between gear shift's more than likely the pto clutch or a line feeding pto clutch is leaking.Will 3pt work when pto is on?Tx Jim
