1938 A carb??
Tim...OK
02-23-2004 05:36:40
Got my A running for the first time this weekend,drove it around the yard 8 or 10 times. But got a question. Can't get it it fire at all without a shot of ether. Has a good spark,did the 3/16" check per Clooneys instructions (wico c),doesn't seem to want to idle down very good either,has a good flow of fuel from the bottom of the carb bowl(DLTX18). Anybody got any ideas? Timing? Open for suggestions.
Thanks,
Tim
Clooney
02-23-2004 10:52:15
 Re: 1938 A carb?? in reply to Tim...OK , 02-23-2004 05:36:40
Tim, a couple of things come to mind on that A..
~If you pass that 3/16 spark test you should have plenty of spark to start it so your problem is more than likely a fuel or compression problem..
~Before all else try another NEW set of spark plugs as a little fuel fouling on the plugs can really cause starting problems..
~I guess the first thing to consider is the age of the gasoline in the tank,, old gasoline can make hand starting very difficult.. If you aren�t using fresh gasoline start with that..
~Next would be starting procedures.. Those old Deere hand starts are all a little different but most of mine like almost no throttle for starting [just slightly off the closed throttle stop] ..
Next would be a possible choke problem [you might want to pull the carb air intake pipe or pull the carb & verify the choke plate is full closing & not bent].. If your choke plate isn�t fully closing it will start very hard..
~Next on the list would be starting compression.. If you have only run it a little the rings might still not be seated back in & causing a loss of compression at cranking speeds. You might try a little 2-cycle engine oil in the gasoline to help the rings seal better at hand cranking speeds.
~Now we get to the carburetor.. You could have plugged internal passages & that not only could cause starting problems but could also be the reason for your erratic idle.. You might try initially setting the carb�s idle needle 2 turns out from seated & the load needle 1 turn out from seated & see if that not only helps the starting but also helps the idle quality. If either the idle needle or the load needle seem to have little effect on the engine idle or power you probably have internal carb problems.. Just blowing air & carb cleaner through the carb passages doesn�t usually get those DLTX carbs clean inside.. Another place to look is for excessive throttle shaft bushing wear.. Loose throttle shaft bushings can not only cause a poor or erratic idle but can also cause hard starting..
~OK, now some things to try.. One thing that I have found over the years that seems to help starting those old hand start A�s is to try closing the petcocks down at least � way during starting. That traps more compression & also allows more fuel to be sucked in from the carb.. Remember you don�t have to spin it fast to start it,, all you have to do is slowly get it over top dead center [not fast just easy]..
~Try using the choke until gasoline spits out the petcocks, then open the choke about � way or more & try starting it again.. If gasoline spits out the petcocks your carb is supplying enough fuel & your starting problem is probably starting procedure, throttle setting, low compression, old fuel or something else.. If you can�t get raw fuel to spit out the petcocks during hand cranking suspect choke, carb, throttle shaft bushing, low compression, or excess side wear on the piston ring lands..
~I believe the reason that ether is helping is that it ignites easily due to already being in vapor form & once it fires it seals the rings to the pistons..
~Look at & try some of the above & post back or E-Mail if you find something that looks wrong or is helping.. With a little more input from you we can get you starting better. You might want to take it out & find some work for it, sometimes all those old tractors need is a good hard workout to get them starting good again..
[email protected]
John T
02-23-2004 07:14:11
Congratulations Tim, Hopefully we can help you get the rest of it ironed out. Heres a few things to look at based on it needing ether to start and not idling down smooth: FIRST, check the plugs and if they are suspect of fouling at all or coated or discolored, try a fresh set, maybe hotter like Autolite 3077 side wire type plugs or equivalent.
1) Remove the air inlet and make sure the choke butterfly plate is closing all the way, tight on the shaft, and staying put relative to where you set it externally. You may as well check the air cleaners lower bowl to be sure its clean and water free. The gas needs to be clean and fresh and water free also.
2) Have you adjusted the carbs top load and idle needles to see if that helps??? The initial rough in for the load is 3/4 to 1 out and 1 3/4 to 2 out for the idle needle.
3) You might want to check for vacuum leaks, at idle theres high vacuum being drawn and if shes sucking in air, that leans the mixture and causes hard to start. Get her idling as slow as possible, and spray Carb Cleaner or WD 40 or an unlit propane torch around the carb, especially its throttle shaft bushings and its mount and around the base of the manifold, and if anyplace causes her to smooth out or speed up, you located a vacuum leak which can lean the fuel mixture.
4) Is the carbs stop idle screw bumping against the spring at idle and, is it posible to remove the governor rod and manually be able to idle her smoother???
5) Once running, will it idle down or run better if slight choke is used????? ?????
6) Hows the compression?? If the rings are worn, youre low on compression plus she pulls less vacuum. See if she will start better if you remove the plugs and squirt some oil inside and turn her over a lil to get oil on the rings to help the seal and compression??? If that helps, she may have ring problems.
7) You asked about timing, the mag should snap to fire right when the flywheels Left Hand Impulse timing mark passes by the flat mark on the tractors side at 3 o clock. If too slow, shes harder to start.
8) If choking helps her idle or run better, you may have some clogged carb passages, post back for more detail on carb cleanign if thats the case. No use posting a bunch of confusing carb cleaning info yet until we know its needed, which it may well be. You might take a look at
Link
in the meantime.
9) Clogged idle passages are more of an idle problem (see link above), while fuel starvation under load and/or needing choke to run better may mean low float levels or a clogged main center brass nozzle. POST BACK your findings.
10) ELECTRICAL If the mags spring is weak, that causes a weak spark when cranking and hard starting, yet they can run fine once over approx 250 RPM when the wind n trip in the mag is no longer operating. It should make a loud sharp SNAP when cranking, NOT a faint dull clunk. You say its a good spark, is it blue and not a faint thin wimpy yellow???? If so and the snaos not loud, you could have a weak mag spring.
SUMMARY. Check the plugs,,,,, start timing per the above,,,,, ,,loud mag snap,,,,, ,carbs needle adjustments,,,,, ,,choke butterfly plate,,,,, ,,VACUUM LEAKS,,,,, ,,if choke helps her run better,,,,, ,, and e mail me at [email protected] or call me at 812-824-4608. If needed, I will advise on carb cleaning later here or via e mail. Thats basically removal of the brass drill plugs (often requires heat) and clean/drill out idle passages behind them with the proper sized 40 or 53 drill bits and wire out smalelr passages, and removal of the center vertical brass nozzle (may require a tap into its bore and bolt washers n nuts to extract) and cleaning it and all its lil side holes.
Let me know, Good luck n God Bless ya Tim
John T Nordhoff
Tim...OK
02-23-2004 08:45:15
 Re: Re: 1938 A carb?? in reply to John T, 02-23-2004 07:14:11
Thanks John T. for all the info,that does give me some things to look at i hadn't thought of. A couple more things that i didn't mention in my first post. I had started out with fresh 3077 plugs along with new wires,I freshened up the carb,removed all the brass plugs and blew thru them with carb cleaner and air plus new float.carb was VERY clean inside,but float was sunk. Have a clean small tank on it with fresh fuel. Mag spring is suspect,more of a thud than a snap,maybe why she starts on ether and not gas?? Thank you for the help,
Tim
John T
02-23-2004 10:52:47
 Re: Re: Re: 1938 A carb?? in reply to Tim...OK , 02-23-2004 08:45:15
Tim, Duane has ya covered there more on the mag and as far as the carb, in the event those idle passages behind those drill plugs were/are restricted, air alone or carb cleaner till the cows come home may NOT clean them properly. The No. 40 and 53 long aircraft type drill bits will insure them clean and the proper size, but DO NOT drill deeper and DO NOT use the wrong bit in those holes. The smaller holes I use my sons steel guitar strings. Anywho, check for vauum leaks and the rest I posted above and the mag clearance as Duane suggested then see how the old girl does. John T
Duane Larson
02-23-2004 10:16:12
Tim,
Based on the previous information in above posts, the impulse should snap sharply and it appears not to. You might try adding a second gasket between the magneto and governor box where it bolts up - as the governor shaft which drives the magneto wears it can move toward the magneto drive cup and push on it, creating additional friction. Spacing the magneto away from the drive shaft with gaskets may help.
Tim...OK
02-23-2004 12:39:41
 Re: Re: Re: Re: 1938 A carb?? in reply to Duane Larson, 02-23-2004 10:16:12
Thanks alot guys, Now it sounds like I've got several evenings worth of things to try :-) the couple of these things i've been around did spit fuel out the petcocks while starting,and mine doesn't,so thats one of the first things I'm gonna look into. Thanks for all the help,I'll post back in a day or two when I've had time to check it out.
Tim
