??CORRECT DIFFERENTIAL LUBE LEVEL 35D???
D-GEEK
05-08-2005 13:09:08
I'm finishing up restoration on my 1935 Model D
and am wondering about the correct lube and level
for the rear end. I also could use any info on the
correct valve adjustment procedure too. Thanks in
advance for any help!!! D-GEEK
Glen in TX
05-08-2005 21:34:16
 Re: ??CORRECT DIFFERENTIAL LUBE LEVEL 35D??? in reply to D-GEEK, 05-08-2005 13:09:08
Tappet Adjustment: Remove tappet cover and turn flywheel until all rocker levers are free just before before left hand exhaust valve opens. Loosen clamp bolts then adjust by tightening adjusting screws until no shake in levers (can rotate push rod some with fingers) and then back off a half turn. Then tighten the clamp bolts and install cover and gasket. A copy of DIR. 225 from JD has all this info in it for Ds #119100-143799 (unstyled). DIR. 108 for #119099 and earlier (unstyled) and OMR2008 for #143800 and later (styled).
Glen in TX
05-08-2005 21:18:10
I agree with using the 140 or 85-140 in the D. They like to leak on the axle quills if you use the 80 or 90. Trans oil level is most Ds which have 41 tooth large sprockets is 7 gallons (28 qts.) or 6 1/2 inches deep in trans. You can tell if you have 41 tooth gears because when cover is off top they are almost touching the back side of case. If you have sprockets smaller than that you have to add more oil of course so sprockets will run in oil. 35 tooth = 8 gallons, 28 tooth = 10 gallons. There was also a 22 tooth shown in parts book but you seldom see those and would add even more. JD instruction manual DIR.225 also says when axle bearing oil seals were removed and mud guard installed to keep oil 10 inches deep (15 gallons) (rice tractors). You probably have the 41 or 35 tooth, very common. 28 was used in DIs and I've never really seen the 22 in a D yet. I had a '35 D with the 28s but it had been changed for roading a thresher is why. That's why there is no check plug on side of D trans case.
JGC
05-08-2005 17:57:35
I was told that straight 140 weight is best, and that it was the original weight used. It is thicker and less likely to leak around older, looser fitting seals. It pours like corn oil or honey. I was also told that the modern multi-grade gear oils have additives that can damage some metals used in old transmissions! I bought the 140 weight at a local specialty lube dealer. There was a detailed thread on trans lube oils about a year ago. Do a search on this board and it should come up!
I could not find a level plug, so I put in the number of quarts recommended in the manual.
With the tractor level, the oil level measures about 6.5" deep thru the trans cover filler plug to the bottom of the case.
The only manual I could find is for styled "D"s after 143,800. It calls for 28 quarts.
The valve adjustment is .030" hot. Again, this is from the I&T manual mentioned above.
My tractor is one of the last un-styled "D"s built in early 1939.
old
05-08-2005 13:32:34
Well what I use in my 1935 B sould be ok for your D also, I use 80W-140
