2130 Hydraulic Trouble
Mitchissippi
05-08-2005 09:55:25
My cousin has a European Version 2130. Hasn't ran it much until this spring. It handled the 3-point disc fine. But when he pulls the 4 row hippers the trouble starts.
We aren't using markers, so he lays off 4 rows, then centers up on the outside furrow to lay off 2 more rows. He had to ride the brake to keep it straight. After about 20 minute of this, the lift won't come up until he shut down the engine and then fired it right back up. After about another 20 minutes, the power steering quit and the lift wouldn't raise at all.
He had just changed the hyd filter and checked the long skinny one right behind it. Said they did not look bad. After we quit, we pulled the little screen out of the pump - it looked new.
Any ideas what the problem might be?
Thanks,
Mitch
G/MAN
05-09-2005 13:50:34
 Re: 2130 Hydraulic Trouble in reply to Mitchissippi, 05-08-2005 09:55:25
In addition to what buickanddeere has said about brake material plugging the sump screen, riding the brake that way is going to heat the heck out of the hydraulic oil, causing it to get thinner and you'll have more leakage in the system. And no, you DO NOT want to ride the brakes like that. Wet-disk brakes will take a lot of punishment, but not continual application under load for extended periods.
Mitchissippi
05-09-2005 14:16:18
 Re: 2130 Hydraulic Trouble in reply to G/MAN, 05-09-2005 13:50:34
Kinda what I was afraid of. He's sposed to change the filter and try it today. I hope he hasn't hurt anything serious.
I'll tell him about the brakes and he's the kind that will take it to heart.
Thanks G/MAN
Mitch
G/MAN
05-09-2005 16:04:02
 Re: 2130 Hydraulic Trouble in reply to Mitchissippi, 05-09-2005 14:16:18
If it's not too late, try to gather up whatever comes out when he pulls the sump screen and filter. If it's a lot of material, I'd seriously consider pulling that final-drive and replacing the disk while the damage may still be limited to that. Maybe you can catch it while the piston, backing plates and whatever other components (I'm not familiar with that tractor) in there are still serviceable. Good luck.
Mitchissippi
05-09-2005 16:13:56
 Re: 2130 Hydraulic Trouble in reply to G/MAN, 05-09-2005 16:04:02
Will do. I'll swing by there this evening and check on him.
buickanddeere
05-08-2005 22:19:32
"He had to ride the brake to keep it straight. After about 20 minute of this". Stop right there. Shut the engine off and step away from that tractor. And never touch another machine again.
If really lucky the oil filter is full of friction material and not steel or aluminium. Put some wheel weights on the front tires and some new single bar or three bar front tires.
Mitchissippi
05-09-2005 06:28:55
 Re: 2130 Hydraulic Trouble in reply to buickanddeere, 05-08-2005 22:19:32
"Shut the engine off and step away from that tractor. And never touch another machine again."
Thanks Slick. Just the advice I was looking for.
Mitch
Mitchissippi
05-09-2005 07:20:37
 Re: 2130 Hydraulic Trouble in reply to Mitchissippi, 05-09-2005 06:28:55
Aw right. I'm back. Just had time to fire a shot back before I had to step into a meeting.
You are right - tractor has no weights and the front tire are as bald as an onion.
He had been running a disc without any trouble. When he mentioned riding the brakes to hold the hippers straight, I told him that was probably the culprit.
He's gonna change the filter again today and see if it'll straighten up. If it does, I'll be sure and tell him DON'T RIDE THE BRAKES NO MORE!
As with most cases, we were in a hurry to beat a rain that never came. Funny thing - folks never have the time or money to set a tractor up correctly before they go to work. Then it costs big bucks and lots of down time to get over it.
Shucks, we were only trying to plant a couple acres.
'preciate the help,
Mitch
Mitchissippi
05-09-2005 11:33:14
 Oh, I liked to forgot . . . in reply to Mitchissippi, 05-09-2005 07:20:37
Before the power steering quit, he could kill the engine at the end of the row, fire it back up, and the lift would pick up. Had to do this on every thru.
Mitch
buickanddeere
05-09-2005 12:27:22
 Re: Oh, I liked to forgot . . . in reply to Mitchissippi, 05-09-2005 11:33:14
Shutting the engine off stop the oil flow into the filter. The outside layer of worn away friction material from the brakes stuck to the filter now slides off. Now at restart a bit of oil can seap through the thinner layer of brake pad material stuck on the filter. I can't get over how someone can think that riding the brakes continously is acceptable? I assume that you will not ever allow your cousin to operate or even touch anything of your's that is valuable or what could be dangerous?
Mitchissippi
05-09-2005 14:11:29
 Heeeeere we go. in reply to buickanddeere, 05-09-2005 12:27:22
third party image
Hoss, the first thing you need to get over is the fact that you my be assuming way too much to begin with.
I know how to take care of a tractor. He does to. And I did not come here to get a sermon on the subject.
You answered my question, and I thank you, but apparently couldn't help but try to belittle me in front of others for not setting the tractor up correctly then riding the brake.
If your mission in life is to save all tractors from a little hard treatment, then you better haul your donkey down here quick - cause we're running the sh!t out of em'!
If we had a hundred acres to work, it'd be different. We might shuck out the expense to "set it up", but he was trying to get 2 acres of ground planted before the rain.
And he would not have made it if it wasn't for my IH!
There are plenty of places on the net to bash folks - I didn't expect it here.
buickanddeere
05-09-2005 15:03:33
 never enough time money to do it right but enough in reply to Mitchissippi, 05-09-2005 14:11:29
Please pardon the rant and I mean no offence but I�m trying to make an important point. There are some people out there who are just dangerous and will never learn. Best to steer clear of them and just pay your extra health and long term care taxes. There is no excuse for short-cuts in doing any task or shoddy workmanship. That mentality makes the overall job cost more, not less. Increases the long term time spent. And worst of all is the circumstances where farm deaths and crippling occurs. Look around at who is making money in a business. It's the neat tidy ones where things are done right. How much are a couple of acres of crop worth in time and money? Compared to pulling the finals off the tractor and rebuilding brakes that should not have been worn out? That machine is out of service, hours are spent on projects that "don't pay" and parts must be paid for. Then during the repair process is where there is more farm accidents waiting to happen from handling heavy parts with inadequate shop equipment. I've seen lots of equipment which has been used and "maintained" by crude hacks. The owner grips about how that *^^*&&*(^ piece of equipment didn't last or stand up. They complain about the shop time and repair bills. And stand there shocked that the auction price for their machine that " runs out good" is little more than scrap parts price. These complainers are often heard at auction sales where going broke, being crippled or killed forced the sale. I'm tired of accident scene calls with crushed body parts, body parts wrapped around shafts etc. The shocked family sobbing as they look at the bloody family member. And the injured party if they are able to. They are the ones to ask about "doing a job right". It�s tough to answer them when they ask �what happened�? Is it a time and money saver to keep that shield on over those chain/belt/gears? Should that pto shield be worth the couple of minutes to re-install? Nobody would ever get caught in that auger would they, no screen needed there? Should that machine have a block put under it instead of just relying on the jack? Is there any reason to shut of the machine before trying to pull stalks out of a corn head? Ask those people blind in one or both eyes if safety glasses or a safety shield would have been all that much bother? May have to speak up a bit as those people are likely partly deaf for not using hearing protection or maintaining mufflers etc.
Mitchissippi
05-09-2005 15:59:43
 Re: never enough time money to do it right but en in reply to buickanddeere, 05-09-2005 15:03:33
I do see where you are coming from, and I appreciate the concern for saftey and effenciency. I can't think of a single one of your points to argue against. And in a perfect world where anyone interested in farming could afford to "do it right" and make a living, we'd all be better off. We could all log on and talk about "how we did it right".
I spend all my extra money just trying to "do it" at all. And I surely don't have to. And I did it a long time before I found this site.
I'm not condoning "doing it wrong" just for the sake of "doing it wrong". But, HAVING to do it right or not doing it at all will force the majority of us out. Which is better for you - The Almighty Farmer. Good luck with that.
It'd also put a lot of mechanics out of business.
Never planned on having this discussion today.
Thanks Dude, you've helped answer my tractor question and given me something to ponder on.
Talk to you later,
Mitch
