2030 german deisel
Muzduz
05-08-2005 08:43:12
I'm looking to buy a small tractor for bailing hay im using a farmall H . I keep running across jd 2030's in my price range, but they are german deisels is there any thing i should look out for? or should I stay away from the german d? thanks Muz
buickanddeere
05-09-2005 06:29:38
 Re: 2030 german deisel in reply to Muzduz, 05-08-2005 08:43:12
What is the engine serial number. The factory location is stamped right on there. The difference between the 20,30 & 40 series utility tractors made in Mannheim Germany and sold in Canada. Vs. the US Dubuque built utility tractors? It's the number sticker on the hood and the English French instruments on the dash. If some dim wit try�s to tell you can't get parts for Mannheims in the US. Tell that person they are full of it to right up to their ears.
j cook (iowa)
05-09-2005 06:16:59
 Are you SURE it's German? in reply to Muzduz, 05-08-2005 08:43:12
So far as I know, and if this is North America we are talking about, the 2030 was a Dubuque-Built tractor, with a Dubuque built, US Made engine! The 2030 is essentially the same tractor as a US built 2440 I happen to have. Generally, I thought that the German built equivilents had different numbering. The GERMAN built 2030 was renumbered and sold as the 1830 when it was exported to Canada, GERMAN 2030's were not sold in areas where US 2030s were also sold, due to the numbering confusion.
If you happen to be in EUROPE, then of course, what you have is the German built Mannheim 2030. It should be as difficult to locate a US BUilt 2030 in Europe, as it is to find a German built one in the US!
Indydirtfarmer
05-09-2005 09:03:44
 Re: Are you SURE it's German? in reply to j cook (iowa), 05-09-2005 06:16:59
I've got one of those "early" 2440's too. Made in Dubuque, Iowa.... Later models, (I think it was around '79 or '80) switched production to Germany. Some subtle differences, but in essence the same tractor. I didn't know of ANY 2030's made outside the US. Bottom line.... Even if it was built in Germany, the Deere tractors built there were just as good, if not better in some ways.
The ONLY problem associated with that tractor (219 cu. in. diesel) was it's inclination to "wet-sleeve pitting". Make sure the coolant was/is serviced and CHANGED frequently. Other than that, you're looking at one solid tractor.
txgrn
05-10-2005 06:57:41
 Re: Are you SURE it's German? in reply to Indydirtfarmer, 05-09-2005 09:03:44
Was in the Deere house the other day and they have a bottle (16 oz?) of treatment for the cooling system to stop that. Don't have to drain and flush or anything more than pop the cap and pour it in. It's a problem with all wet sleeves. OTR trucks have an ionic filter for the coolant to prevent that. Maybe later model tractors do too.
Mark
mitchp
05-08-2005 20:44:32
i've got a german made JD, the motor was actually made in france, but its a bulletproof engine, i've put over a 1000 hours on it in the past few years and had no problems at all.
jdemaris
05-08-2005 18:35:45
I was a Deere mechanic, but my memory may be off a bit. As I recall, there's hardly any difference between the German built tractors and the U.S. built. We sold pleny of 2030s and they were just as good as anything else Deere had. German tractors had mostly the same parts as the U.S built - but on some models the hydraulic and fuel injection system varied slightly. Some of the German tractors had a small German built hydraulic pump, and also, some had a CAV injection pump instead of the U.S. built Roosamaster. The CAV is a better pump anyway. Also, the Deere engines, when built in Germany, were held to tighter machining tolerances than those built in the U.S., so, if anything, they were sometimes better. For reasons I cannot explain, that ended when the 40 series came out. At that time, we started having problems with German quality control. Perhaps a U.S. labor union got a foothold over there. Whatever the problem was, it was fixed fast, and the problems ceased.
