Can I make My 6 Volt generator put off 12 Volts?
wilamayb
05-07-2005 19:46:37
My late B is very strait,and original except for the fact that it has an alternator. What are my options to put an original looking generator on it? Will one off a 50 work? Will changing the windings on a 6v work? The reason for 12V is simply because it starts so much better, and my lights are 12V (they arent original, but they look pretty darn close and put off much more light!!) Thanks so much for your help.
GeorgeH
05-08-2005 14:13:54
 Re: Can I make My 6 Volt generator put off 12 Volt in reply to wilamayb, 05-07-2005 19:46:37
I recently had a 6 volt generator converted to 12 volt. Rest of tractors electricals were already converted to 12. Cost was around 110 dollars including a new front bearing, leads, field windings, and new regulator. Worked fine.
RayP(MI)
05-08-2005 11:49:18
My generator shop converted the 6v generator on my B to 12v by changing the regulator out with a 12v unit. Output is low, but if you"re not using lights all the time, not a big problem. Starting our B doesn"t take much out of the battery - just a couple turns!
John T
05-07-2005 20:20:01
Its pretty easy to locate and install a later model Delco or even a 12 volt Generator of the same vintage of your tractor which, when coupled with a 12 volt Voltage Regulator, will work fine. Its also possible to have an old 6 volt unit converted over to a 12 volt (Check with Kenneth at Classic Generators in Texas) and I have even used 6 volt Generators with 12 volt Voltage Regulators and no other adaptions or modifications whatsoever and they charged 12 volts and worked.
Is yours converted to Negative Ground??? They were originally Positive ground, but when using alternators many got changed over. The Gen can work either way if Polarized and wired correct and the Voltage Regulator is suitable for your ground, but to stay as original if youre gonna use a Generator, I would take her Positive ground. If the ammeter reads bass ackwards, you would have to reverse its leads.
Is it a Magneto or a coil battery ignition?? If a mag nuttin matters, but if it happens to be a battery powered coil ignition and you change from 6 to 12 volts, you need EITHER a full 12 volt rated internally ballasted coil or else a 6 volt coil and an external voltage dropping (12/6) ballast resistor.
Basically a Gen dont know what voltage its supposed to put out, the faster it turns or the greater the magnetic field (by increasing Field current) the more it generates. Thats why its possible to make them work with no chnages except for a 12 volt VR HOWEVER thats NOT the recommended or best engineering way as added field current may cause overheating of the Field windings.
Sooooo ooo, you can find a Delco 12 volt unit and use a 12 volt VR,,,,, ,,,,or have a 6 volt professionally converted,,,,, ,,,or not have it converted and use a 12 volt VR. Just make sure the VR is suitable for your ground and Polarize the Generator and make sure of coil voltage (if a coil ignition) and reverse the ammeter leads if necessary.
Post back any questions, good luck n God Bless
John T
wilamayb
05-08-2005 10:55:56
 Re: Can I make My 6 Volt generator put off 12 Volt in reply to John T, 05-07-2005 20:20:01
I am already running on 12 volt, negative ground. You stated that It would be farily easy to find a 12 volt replacement that would bolt up. What exactly should I look for? (which models? will I need diferent brackets?) How about a 50 JD will it be the same? If in fact I do use a 6V gen with a 12V cutout relay how much faster could I spin it without overheating? Can't I can just install a smaller pulley to increase the driven speed? Thanks so much for all your help!!!
John T
05-08-2005 11:31:00
 Re: Can I make My 6 Volt generator put off 12 Volt in reply to wilamayb, 05-08-2005 10:55:56
My SM 2029 John Deere Manual shows a ton of different Delco Remy Model Numbers, and I'm fairly sure many of them such as the 50 you mentioned will bolt right up where an old 6 volt Generator was used on that Model B, but to try n figure out all the exact detail n specifics would be quite a chore. Easiest way would just have your old 6 volt unit and compare it face to face when getting a later model 12 volt unit. If you happen to see a smaller diameter but similar shaft size and mount of a pulley you could swap it out for faster RPM's, but frankly, I wouldnt worry all that much as any of them are relatively small and you may not (without looking harder) find one "extremely" smaller anyway. True, Ive seen some near the size of the generator yet others like 2 1/2 inches and smaller would still be better if using a 6 to charge at 12 volts. Likewise, theres probably no need to worry about over revving or overheating any of the generators you find, since the tractor dont turn many RPM's and even the smallest pulley available isnt all that much smaller than the standard.
In other words, I wouldnt worry much so long as it mechanically fits. True, if youre using a 6 volt to charge at 12 volts a smaller pulley would be better, but I would just try whatever you find.
Tht main thing if you use an old 6 volt to charge at 12 volts is the proper Voltage Regulator suitable for your polarity, but since they were all originally Positive ground, thats the way I would configure your new system even if you have to swap the ammeter wires and battery. That way if you buy say a Model 50 Generator and mounted Voltage Regulator already set up for 12 volts and Positive Ground, youre probably good to go after installing and polarizing and maybe an ammeter lead swap and not worry about any pulley changes or VR replacements.
IF YOU USE AN ORIGINAL 12 VOLT (instead of using a 6 to charge at 12) THEN THERES NO NEED TO WORRY ABOUT A PULLEY SWAP
You mention cutout relays??? Some of the old B's used the simple 2 wire cutout relay and the combination light switch generator field control, but if going to 12 volts, I would use a full fledged 3 or 4 wire Voltage Regulator and get out of the cutout relay and combo light switch business altogether.
Good luck, sorry I dont have all the exact specs n dimensions and Delco data to answer better, but like I say, just get one that mechanically mounts the same (should be many, change to a smaller pulley if its convenient on the 6 to 12 application, otherwise dont worry) and use a 12 volt 3 or 4 wire VR and install the battery Positive ground and polarize n see what happens.
John T
