Cracked Head
Mattg
05-07-2005 18:59:16
Hello All,
Well it turned out we have a cracked head on our 60. We took it apart and took it to a shop to have it pressure tested, and turns out there is a crack on the left side. The shop just said JB Weld would fix it. I am looking for a new machine shop.
I have found a company up by me that can weld Cast Iron. Has anyone had any sucess with this, or am I better off finding a new head? I can get it welded a lot cheaper than a new head, but what good is if it doesnt work.
Thanks.
Matt
Joe S.
05-09-2005 14:07:00
 Re: Cracked Head in reply to Mattg, 05-07-2005 18:59:16
Had a JD 70 head welded and worked for untold hours plowing is second gear. You will never know it was done once bolded up.
JGC
05-09-2005 11:31:39
You are better off with a head that has not been welded BUT it can be difficult to see the weld unless you really know what to look for.
I just had a head planed that looked unwelded.
The planer did a beautiful job and the machinist showed me a very subtle colouration and pattern in the head material where he's sure it was welded.
Many heads this old have been welded at some time in the past so unless you know the history of the head, there's no guarantee that it hasn't been repaired before.
Really good shops can fix almost anything, but up here in Canada, it's very expensive to weld a head! #@$%&^*$%^&$%^&
old
05-07-2005 21:11:51
I have a JD-60 head it does need to be rebuilt but from what I can see it has no cracks. I'd sell it for a fair price
