720 carburater
Russell G. Mon
05-07-2005 18:50:46
I fired up the 720 today and was going to adjust the idle screws but I decided to take the float bowl off. I found all kinds of deposits in the bowl. So I took off the float and valve sprayed it down with carb cleaner and wire brushed the sides where the steel balls were inset. I put it all back together again but the tractor will start with no choke still and it seems to be getting to much fuel as there is a black smoke that is emitted while running. The tractor will backfire when the throttle is advanced. Is this a carb problem or timing. thanks for the help
Jeff Oliver
05-07-2005 21:19:32
 Re: 720 carburater in reply to Russell G. Montgomery, 05-07-2005 18:50:46
Might want to check your float in the carb. Although it could be something else tha sounds like what happens when it goes bad. I would probably take he entire carb off though and give it comlete cleaning and make sure the jets are open and all. This is of course after adjusting the carb or trying to get it in that way. Could just be a piece of trash in the carb that worked loose.
