Diesel getting in lube oil
Jerry
02-22-2004 23:17:22
have JD 300 diesel is leaking in to the engine lube oil(big leak) could it be leaking by the diaphram in the transfer pump, or would leaking by the seals on the injector pump shaft be more likely are their any other possibilities. I understand that the 300 engine and the 1020 are the same.
Thanks for any input Jerry
Gary Mckenzie
02-23-2004 06:43:57
 Re: Diesel getting in lube oil in reply to Jerry, 02-22-2004 23:17:22
Are you certain that it's diesel? I'm not familiar with the 300, but some early 1020's had a separate power steering pump on the timing cover that could leak hydraulic oil into the crankcase. I would make sure that it is diesel in the oil before removing the injection pump, especially if this "big leak" occurred suddenly. Of course if you don't have this power steering pump, then David's advice is right on. Just be sure that if you remove the injection pump for seal replacement to tie the throttle lever in the wide open position before removing the shaft and check the front bushing in the pump for wear. Hope this helps!
david val
02-22-2004 23:30:46
it's easy to remove and check the fuel transfer pump (you can apply low air pressure to the inlet side and plug the outlet, dip in a bucket of water and look for bubbles from the pump body).
if the pump is ok then the injecton pump seals are next.
david
