J.D. 430 Revercer
jd520
05-07-2005 17:55:42
on a 430 W with a direction revercer ,is there any maintenance required? I am changing tranny oil, and am wondering if the same oil is in the revercer or if it has it"s own reservoir?I have no book yet . thanks in advance JD520
Lavoy
05-08-2005 19:09:12
 Re: J.D. 430 Revercer in reply to jd520, 05-07-2005 17:55:42
Reverser uses what Deere used to call 303 fluid, now I think it is called Hy-Gard??? What it is, is a common systems fluid, the type that is used for transmission and hydraulics starting with the new gen stuff. Mobil calls it 424, I think IH calls it Hy-Trans.
I would drain it, refill with kerosene or diesel, run in place for a couple of minutes, and drain agian, then refill.
Lavoy
