3020-4020 parts swap?
gtg155
05-07-2005 12:08:55
will the pistons from a 4020 fit in a 3020. engine is gas. i checked the deere online parts page and the pin is the same 1.25, and the bore is the same 4.25 but what about the compression height? also if i were to put in lp pistons would this give more compression?
Gerald J.
05-07-2005 12:37:46
 Re: 3020-4020 parts swap? in reply to gtg155, 05-07-2005 12:08:55
I think generally there are 2/3 as many 4020 parts in a 3020, but you have to watch the vintage. 3020 parts change significantly at SN 123,000 and 4020 at SN 203,000. Deck height (at least for diesels) is one of those changes. I see in my old Central Tractor catalog that there are two different rod numbers, one for before the SN break, another for after, but all (3020 and 4020 gas) used the same rod bearings, but not the same mains. Rings also are different across the SN break.
I have a JD SB talking about not swapping diesel pistons because of the change in deck height makes for hard starting if the new pistons were used in the older blocks.
I doubt you will find JD specs showing the pin or deck height so to be sure you will have to measure them to compare, or not to take a chance and to use only for sure 3020 pistons of the right vintage.
LP compression ratio is higher. Probably from a taller piston.
Gerald J.
