JD 316 Front PTO won't work, alt light stays on
mrkbuchholz
05-07-2005 11:21:26
I have a JD316 and the front PTO will not go. I noticed last season that it would start the first time you used it, but if you turned it off and then started it up again, it would not go, had to let it cool down and then it would go again. Is it just shot and I need a new one or I also the alternater light stays on all the time now. Is it possible I just don"t have enough juice to power the front PTO? Any thoughts
Henry J
05-07-2005 12:04:14
 Re: JD 316 Front PTO won't work, alt light stays o in reply to mrkbuchholz, 05-07-2005 11:21:26
MrK
Put a volt meter across your bat terminals when the thing is running and see what the voltage is. If it is around 13.2 i would think that it is charging but something is wromg with the sensing system. Or maybe it should be more than that, I havn't checked mine lately, but the camper is 13.2
kdagenais
05-07-2005 11:35:50
Hello,
Sounds like you need to adjust your air gap a little bit. If I understand you correctly you say it turns on fine when the tractor is cold but once you warm it up once disengaged it will not engage again. If this is the case all you have to do is tighten the 3 nuts that have the springs on them on the PTO. I usually try a 1/2 turn a piece until it works. Good Luck and keep us posted.
