Is this a cracked Block?
Mattg
05-06-2005 14:28:03
Hello All,
I have been helping another friend on his JD 60. His has been running fine until now. We pulled it out after the winter is over, put water in it, and started right up. But after running for about 2 hours and getting the tractor up to temp, we are seeing some strange things in the radiator. The water is frothy, and it seems to have bubbles in it. I dont see these bubbles when the tractor first starts, but after a bit of running. We also had to add about 1/2 gallon of water to the tractor after 2 hours of running. Is this a sign of a crack somewhere? what would be the best way with out dissasembling the whole machine to test to find out?
Thanks.
Matt
Dave in Ohio
05-06-2005 19:21:34
 Re: Is this a cracked Block? in reply to Mattg, 05-06-2005 14:28:03
Back preasure in the radiator at high idle is a sure sign of a blown head gasket. If it were mine thats where I would look first. Could be a cracked head but my money is on the gasket.
Mattg
05-06-2005 14:34:55
I think I might have figured out my problem. I was just idiling the tractor and at low idle everythin is fine. At fast idol the water really starts churing and spilling out the relief hole, and then when I slow down the tractor it goes back to normal. So maybe it is just the water pump really turning and churning the water that I am seeing. Is that possible? My main tractor is an B and I dont have a water pump on that one so I dont know if that could be causing my issues.
Thanks again for the advice.
Matt
mike brown
05-06-2005 16:41:54
 Re: Is this a cracked Block? in reply to Mattg, 05-06-2005 14:34:55
Not likley the water pump.
More likley needs a new head gasket. It's not that bad a job. Check the compression and see if one cylinder is low. Take the radiator cap off and see if you can smell exhaust. Could be a cracked head also.
It's best to use antifreeze instead of relying on draining to prevent freezing. Sooner or later you will guess wrong on overnite low temps and freeze it up. Also there is the risk that there is a pocket of water that didn't drain.
