4020 Hydraulic Oil Cooler
MRN
05-06-2005 13:49:19
A small pin hole has developed in the top end of my 4020's hydraulic oil cooler. The core is ok it's the very top part (looks like a resevior) that is perforated. What is the best couse of action for repair? Will taking it down to my local radiator shop and having it brazed be ok? Or is the cooler pressurized enough when running to blow out a brazed spot? The hole was caused by a metal hyraulic line rubbing the cooler.
Thanks.
txgrn Ha!
05-07-2005 05:42:45
 Re: 4020 Hydraulic Oil Cooler in reply to MRN, 05-06-2005 13:49:19
I just had the same problem with my 4010 a couple of weeks ago....a very tiny pin hole at the top of one of the fins. Scattered oil all over everything up front.
I went to a radiator shop and he said it was aluminum; couldn't fix it. Took it to a welding shop and said weld my alum cooler. He tried to do that and failed. Said it's not aluminum; it's TIN. Said he got a magnet to stick to it so he brazed it with brass. Works just fine. $40.
So I go home and look up tin in the dictionary, and sure nuf, it's magnetic.
Mark
Jason Z in MO
05-06-2005 14:06:45
The cooler not on the high pressure side. Pulling the cooler is not a lot of fun but is about the only way to get things cleaned up. If the oil has been dripping around the core and sucked in to the radiator, it probably has attracted a lot of dust. Which makes a kinda oily mud.
If pulling it off isn't required, I would try to fix it in place. Clean it really good, either solder, weld or braze. I would even try a good JBWeld patch.
msb
05-06-2005 18:36:59
 Re: 4020 Hydraulic Oil Cooler in reply to Jason Z in MO, 05-06-2005 14:06:45
Cooler pressure can go as high as 200 PSI and solder won't hold it.Either braze it or use silver solder.
