A few specs
jdemaris
05-06-2005 06:46:17
Diesel engine is 270 cubic inches as opposed to the gas engine at 227 or 241 cubic
inches. Wet-sleeve design. Non-turbo diesel engines put out less horsepower per engine size as gas engines,
so usually the gas engines are small in order to have matching horsepower ratings. Diesel
with Synchrorange trans. rated at 72 PTO horse, whereas when coupled to a Powershift
it's rated at 65 PTO horsepower. 4 1/4" bore by 4 3/4" stroke. Fuel efficiency averages
around 12.7 horsepower hours per gallon of diesel fuel. For comparison, some of the
most fuel efficient diesel tractors ever tested are up around 18 horsepower hours per
gallon (Deere 720 and 1650) and some of the worst fuel hogs are in the low 9s e.g. the
Case 610 and several Steiger tractors. Four cylinder engines have a natural "inbalance" problem which gets worse the bigger
they get - whereas three and five cylinder engine do not have that problem. So, often,
four cylinder engines use either balancing shafts or gears to cut down vibration. The
3020 engine uses balancing gears in the bottom of the engine. 3020s came with large body fuel injectors (Bosch or Scintilla) in early models and Scintilla or Roosamaster pencil
injectors in later models. Injector pumps were either C series or DB series Roosamaster
Stanadyne. Injection pumps for 3020 as follows: CBC431-1A1, CBC431-7AL,
CBC431-8AL - or with the DB series: DBGVC431-3AJ, JDB431AL2401 and
JDB431AL2722. Fuel delivery at full throttle is around 11-13 ccs per 1000 strokes, and
roller to roller setting for fuel deliver is 1.978� to 1.983� All injection pumps as used on
the 3020 are distributor type pumps - i.e. there is only one little injector pump that feeds
all four cylinders. Fuel is distributed, somewhat analogous a distributor cap in a gas
engine. Industrial equivalent to the 3020 is the 500.
