2010 running like crap/please help
paulie
05-06-2005 06:07:41
my 2010 was running pretty good then all of a sudden it starts acting up,she starts right up everytime and runs good for a little while then starts spitting and popping sometimes throwing a blue flame out the exhaust,like its too lean but when i check the plugs they are as black as coal,i have messed with both idle &load screw trying to dial this out but nothing seems to work,i checked and replaced coil wires and put dry gas and fresh fuel in tank.any suggestions would be greatly appreciated
LATarheel
05-07-2005 11:51:42
 Re: 2010 running like crap/please help in reply to paulie, 05-06-2005 06:07:41
Pauie, I"ve seen cars act like this when the coil was weak. If the other ideas don"t help try substituting the coil. SteveA
Britt
05-06-2005 21:23:30
Paulie,
Pull the drain plug from the carburetor. Catch what comes out. See if it has water & other crud in it. Check the sediment bowl for water also. If you need a fuel filter for it NAPA has them. P/N 3043 List $6.48 net $4.23.
Sounds to me like you got a load of wet and or dirty gas.
Britt
KEH
05-06-2005 15:46:36
Check to see if switch is OK. My 2010 would not run without choke out, burned out points. New switch cured problem. Good luck. KEH
paulie
05-06-2005 06:57:49
no pulling the choke out only makes it stall out
Henry J
05-06-2005 06:25:10
When she starts popping and cracking pull out on the choke. If this helps or not post back and surely folks can get closer to the problem.
