730 D Electric Start Gett'n it Cranking
Scotty
05-06-2005 04:41:58
Does anyone know how to get this beast cranking by jumping the starter right at the soloenoid ? Thanks for any help....
Scotty
buickanddeere
05-07-2005 05:16:58
 Re: 730 D Electric Start Gett'n it Cranking in reply to Scotty, 05-06-2005 04:41:58
Are you sure you want to cobble something together on a partly disassembled tractor and end up with the engine running? It"s operation in such circustances where a majority of accidents or damage occurs.
Tx Jim
05-07-2005 04:07:31
 Just pull start it!!!! in reply to Scotty, 05-06-2005 04:41:58
Scotty, it would be easier to pull start it than jump start IMHO.Tx Jim
Scotty
05-07-2005 20:10:31
 Re: Just pull start it!!!! in reply to Tx Jim, 05-07-2005 04:07:31
Can't Tx Jim, got all the wheels off and the console with the steering wheel is also off. Every thing is apart because it needs attenion bad . the engine was stuck but got it freed up now I'm try to get it cranking to see what I got as far as a engine goes . Thanks Tx Jim....
Scotty
Scotty
05-06-2005 10:10:35
Thanks Merle, I have two 12volt batteries hooked in series to make the switch from 4 six volt batteries. I think I have the starter hooked up right I don't have the console on the tractor so i don't have no button to press to crank the starter and I want to crank the motor with the starter but I don't know how to jump the solenoid to engauge the starter . Thanks .... Scotty
Merle Hoppenworth
05-06-2005 06:44:00
You would need a source of 24 volts to jump it.
This will cause you to "experiment" with alot of voltage and amperage. BE CAREFULL.
It may be safest to start with new cables and 4-6 volt batterys like the manual says. My experience is that new batterys and cables and tight connections are worth the investment. With 4-6 volt batterys you have enough amperage to melt off a battery post if it isn't tight.
I've had 2 JDs using this system and I really like them but this isn't the area to (try to get by).
mike brown
05-06-2005 14:05:58
 Re: 730 D Electric Start Gett'n it Cranking in reply to Merle Hoppenworth, 05-06-2005 06:44:00
OK;
I just went to the barn to look at mine.
Standing on the right side of the tractor with your belly button against the end of the belt pully.
1. 24V pos to large lug on the end of the starter.
2 24V neg to large lug on right side on end of selenoid.
3. Large lug on left side end of sel. should be connected by a metal bracket/strap to the large lug on the top side of the starter just under it.
4. There are two smaller spade connectors on the selenoid. The one on the right goes to the starter button. The one on the left goes to to the pos. lug on the end of the starter.
5. To bypass the starter switch, use a large screw driver to jump across the small lug on the right side of the selenoid to the large (neg) lug on the right side of the selenoid just above it.
It works on mine.
If you're going to try to get it going you will need a helper to hold down the decompression pedal.
BE carefull!!! Clutch out, tractor in neutral, brakes on. Were gloves so you dont get burned. 24V can heat up metal in a hurry if the screw driver shorts to something.
