50 B rear wheel width adjustment
JD50B
05-05-2005 20:01:14
I need to adjust rear wheel width on my tractor to have it fit on 82" wide trailor. After reading past postings about how hard it is to get the wedges to move and I am thinking of alternatives. Has anyone ever tried to leave the wedges where they are and simply use spacers (3") and longer bolts to mount the wheel rim to the wedge? This would be for transport only? My tractor is on the other side of the state so I can't see how it is assembled. I do know that the wedges and hubs are on the outside of the axel. What I don't know is if the rim in this case is inboard or outboard of wedge. It would need to be inboard to allow me to space the wheel in closer.
Also, what is the approximate weight of wheel (air filled) and could I move it by myself?
Any thoughts, comments or cautions would be greatly appreciated. Even a good laugh.
Thanks in advance
JD 50 B
Eli
05-06-2005 05:32:21
 Re: 50 B rear wheel width adjustment in reply to JD50B, 05-05-2005 20:01:14
If you have cast rear wheels everything is right for your theory. I don't think you'll be able to reclamp the rim to the axel without a very intricate spacer. I can tell you how I move the wheel clamp if your interested I'm setting one in today. I bought a tractor at an auction A few weeks ago and I set it in at the auction with a few simple tools. Remember you only have to set one in. Look at a tractor near home before you go. Good luck, Eli
JD50B
05-06-2005 20:05:26
 Re: 50 B rear wheel width adjustment in reply to Eli, 05-06-2005 05:32:21
Hi Eli,
I would be very happy to know how you set one in. I would love to get the tractor home (it has been 2 years) but my time is very limited these days and the prospect of hours or days of pounding on the wedges makes that impractical.
Thanks in advance
JD50B
