3020 3point stuck
VernSD
05-05-2005 12:26:03
I have a 3020 gas serial 11T62626 that the 3 point is stuck in the up position. The handle on the console will move a little but only bends the rod connecting to something down below. What is wrong and how do I fix it? I have ordered the manuals.
Thanks!
VernSD
05-06-2005 05:06:24
 Re: 3020 3point stuck in reply to VernSD, 05-05-2005 12:26:03
Thanks!
msb
05-05-2005 18:41:11
Remove the rockshaft cover on the right side under the seat.The control cable is frozen to the operating arm of the 3 pt.hitch valve . Its located at the rear of the transmission case.Remove the E clip and spray generously with penetrating oil.Slowly and gently work the eye off the pin.That is usually the first place they freeze up.Don't try forcing the lever or you will snap the cable end off .Clean the parts up and put some Never Seize on the pin.
The second place is the cable itself.Once you get the cable end off,try operating the lever.If it is still stuck then you might get the cable freed up by once again using a lot of penetrating oil Remove the cowling just in back of the hood and squirt the penetrant on the cable where enters the cable housing.If not then the platform will have to come off to replace the cable assembly.
Gerald J.
05-05-2005 12:34:11
You need the flexible push-pull cable. I don't know the part number off hand, but it cost me $93 at my local JD dealer two days ago to fit my 4020. You have to lift out the operator platform to remove it. There will be a lot of dirt under there. You will have to take the pin out of the differential lock pedal to get the operator platform out. You will also need to have the top or cowl cover off. And you will need the cover off from the rock shaft valve, the right side under the seat.
The upper pinch clamp bolt goes in a groove near the end of the housing, and the rear clamp (which is only loosenable with an open end wrench) also has to clamp on that bolt groove.
When its adjusted properly you get maximum range up and down, my book for 4020 says 76 degrees plus or minus one. You have to watch that you don't get the lever on the rockshaft valve moved too far. You will notice that the hydraulics load down the idling engine if you try to push it too far to the rear.
I didn't look to see if the I&T manual covered it, I have the SM-2039 that fits my vintage of 4020. Be careful about manuals because I'm sure there are separate manuals for old and new 3020 as well and they don't interchange well.
Gerald J.
