4230 steering
Steve Ga
05-05-2005 10:58:35
I am looking at 4230,8 speed,7700 hrs.it cranks and runs great,no smoke,leaks,knocks from motor.The hyd. pump moans,the steering wanders.You may turn wheel and the front tires move moments later(slowly)Could this be just pump?or is the system got filth in it?Also hard to get into reverse.How much does a rebuilt pump cost?Thanks for some help
Steve Ga
05-06-2005 13:29:07
 Re: 4230 steering in reply to Steve Ga, 05-05-2005 10:58:35
Thanks for the input,I looked again today.The trans fluid is clean and on the low mark of normal.The shifting is some thing that will probly be okay.A fellow there that was familiar with that trans had no problem. I drove it around and the steering will work enough to get around in a big area.But there is definatly a problem.You can turn the steering wheel all the way around and the tires may start to turn moments later. I have heard along the way that a bearing or sync. may be out of trans. causing metal bits to get into system ahead of filter?? The story is there was some work done a year ago and it stopped,now its doing it again? Thanks,Steve
Jason Z in MO
05-06-2005 13:58:54
 Re: 4230 steering in reply to Steve Ga, 05-06-2005 13:29:07
Steve,
The normal cause of metal in the transmission is from the brakes. They run in the oil which makes them last forever. Well not quite forever... but when they do go out and you get down to the rivets on the pads, you don"t know it cause they are running in oil. Before you know it, its metal against metal and the shavings get into the system. There is a sump screen that will pick up some of the trash. (I just learned about the pick up screen myself) The hydraulic oil filter picks up most of the trash. To fix the brakes you have to pull the wheels and the final drive housings. I when through it a couple years ago.
There is also a filter screen in the main hydraulic pump.
On another 4020 project I had the same steering issue. It was fine to the left but really slow to respond to the right. The steering valve has a bleeder valve. After I followed the bleeding procedures it was fine. Guess it just had air in it!
That saved some bucks!
Mark / Wi
05-06-2005 06:20:30
It sounds like it could be low on oil. That would be my first check
msb
05-05-2005 18:46:20
Sounds like either the steering valve or the steering motor or both needs rebuilt.I would advise you to not buy it until you are satisfied it is fixed.Shift problem too.That could be a very expensive repair.
