4050 CID
Walter Squires
05-05-2005 09:43:31
Didn't the 4050 come out with a 466 and they changed it in later production to a 369, WHY?
WTW
05-05-2005 13:12:26
 Re: 4050 CID in reply to Walter Squires, 05-05-2005 09:43:31
Walter, The 4050 did come out first with a 466D (Non Turbo) and later was replaced with a 359T Turbo charged engine. The reasoning was due to fuel economy. The 466 burned more fuel at the low HP setting than what was acceptable to produce its rated power. Good chance there may have been other reasoning behind it also and it probably had to do with cost. The 359 was a good engine and would easy meet the HP they wanted in this model and do it on less fuel. DW
buickanddeere
05-07-2005 12:22:21
 Re: 4050 CID, mixing waterloo with dubuque? in reply to WTW, 05-05-2005 13:12:26
Come to think of it. That would be adapting a Dubuque pattern engine to a Waterloo tractor? Isn't there demand for adapter parts to put the common & cheap four cylinder diesel Dubuque engines. Into gas or diesel Waterloo 3010/3020 because old four cylinder Waterloo's are big $$$ for the engine balancer parts?
