General Maintenance 185 Hydro
Steve Daugherty
05-05-2005 09:05:24
I"ve got another mower that is a 185 Hydro I also picked up in trade. (My 111 is almost back in business thanks to the help I received here before!)
Looks like the 185 wasn"t very well maintained. I"m worried about the oil level for the transmission / final drive. There is a fill tube under the seat but no visible way to check the level. Can someone please advise how you check the level?
Secondly, there is a lever labeled 1-4 on the lower left section of the deck that seems to be broken (Just free floats). I"m assuming it has something to do with deck height adjustment since my lift lever doesn"t lock unless you lift up on the deck. The lift linkages were reversed and bent. (Pins pointed in instead of out.) I straightened them and put them on correctly but the lever lock issue showed up afterwards. I"m assuming that I scewed an adjustment by "fixing" the linkages. Can someone advise how you correctly set the lock level.
Thanks,
Steve
