70D pony
Ag Teacher Ben
05-04-2005 18:56:52
I am an ag teacher trying to get one of my students 70D going. We have put new coils and points on it and have a 6 volt battery hooked up positive ground. We are bypassing all the switches and gauges at this point by hooking a hot wire directly to the distributer terminal. The problem is the left hand (rear} coil and points get way too hot. I don't see any shorts. Anybody got some advice?
720Deere
05-05-2005 19:42:54
 Re: 70D pony in reply to Ag Teacher Ben, 05-04-2005 18:56:52
I might be way off base here, but wouldn't it misfire if the coil had a short? My bet is the high voltage. There is a resistor built into the switch and without it the coils are seeing close to 6 volts rather than 4.5 volts.
buickanddeere
05-05-2005 00:32:17
The coils are to be used with bypass starting. Normal running voltage is about 4.5V .
Blksmok
05-04-2005 19:24:33
The left coil is shorted out and may be due to a sharp edge on the center coil bar that scraped the thin insulation off of the inside of the square hole in the coil as the coil was being slid onto the bar. Also, make sure the lead wires (one to the condensor and one to the side terminal)are not being pinched between the coil and the backing plate. My guess is that it's shorting out to the center bar, especially if you pounded on the center bar to remove the old coils.
