46GM parts
junkman
05-04-2005 18:03:48
I am looking for a clutch/belt pulley cover & starter tank for 46 GM. Will parts from an A fit? Or will G only work? Going to Waukee Swap meet if anyone is going. Also looking for the center link or top link for the 800 series 3 point. Thanks
JDGnut
05-05-2005 19:22:13
 Re: 46GM parts in reply to junkman, 05-04-2005 18:03:48
If you are talking about the cover on the end of the clutch pulley.. Many tractors had the same size cover.. A, G, 60, 70,63-730.. If you need the shield behind the pulley.. make sure your 1st reduction cover is made for the shield.. I have one that doesn't have any mounts for that shield.. the others all have it.. Good Luck
JDGnut
DP
05-05-2005 15:26:25
Easydoesit is right. Only G parts will work. Aslo take a good look at your hood where the tank fits in. There are at least two styles. Mine has one that bolts from the top, and I had quite a time finding the correct one. I found several of the others, but was beginning to think there wasn't any like I needed. Good luck in your search. Don
easydoesit
05-05-2005 12:18:43
Only G parts will fit a G. Have fun at Waukee. Wish I could go.
easy
