JD 'B' decals
souNdguy
10-24-2003 20:59:34
Anyone have a listing of where the various decals go on a JD B.
I bought a JD licensed set, for the B.. but it covers 1940 thru 1952.. mine being a 1950.
I know the obvious ones.. like the 'jd' on the back of the seat top cushion, the hood side 'B' and 'JD ' and the 'powertrol'. As those decals are still showing thru though a bit worn.
I see a rollomatic decal in the set.. not sure what that is.. or if mine has it... sn is 269606..
thanks
Soundguy
T213R
10-25-2003 07:07:54
 Re: JD 'B' decals in reply to souNdguy, 10-24-2003 20:59:34
The "Roll-O-Matic" decal is used on late styled tractors equiped with that kind of narrow front end. Also, you possibly acquired two different air cleaner decals. Since you cannot possibly have both a "UNITED OIL BATH" and a "DONALDSON" air cleaner on the same tractor, discard the "UNITED" decal, since your tractor has a DONALDSON on it. If your set contains a "CUSTOM POWERTROL" decal (I bet it does---all of the cheap sets do) you should be aware that the B you own does NOT have CUSTOM POWERTROL, since that appeared on 20 and 30 series tractors in late 1956-1960. Your tractor would have plain old HYDRAULIC POWRTROL which is a different sticker. If your tractor has a WATERPUMP, it may also have a pressureized water system. There will likely be a decal in your set which warns about pressurized cooling systems and warns you to open slowly. However, if the radiator cap on your tractor is a big round thing, about 4 inches across, and scfews onto a big wide mouthed flange, you have a THERMOSYPHON cooling system, which is not pressurized. Throw the "Presurized cooling system" decal away also. There will likely also be a number of small "WARNING" type decals. The one that is about 3"x3.5" and goes on the metal plate on the back of the battery box seat is the only one you need. If you don't HAVE one that size, throw them ALL away and see if you can locate one of Brandon Pfieffer's "Tractor Plates". The John Deere decals for the side of the hood are positioned so that the forward most letter is about 3-4" from the seam in the hood where the nose pieces are mounted. There will be a smaller "JOHN DEERE" which is centered on the "Medallion" (the nose piece covering the steering sector) at the very front of the tractor. If you have the proper, metal backed, upper seat cushion, there is another "JOHN DEERE" decal which should be positioned there. Are there any "other" decals" in this set?
souNdguy
10-25-2003 22:13:58
 Re: Re: JD 'B' decals in reply to T213R, 10-25-2003 07:07:54
Thanks for the info. I believe the only other one I saw was a pto decal.
And yes.. I still have the metal backed top seat cushion.
again, thanks for the info.
Soundguy
gene
10-24-2003 21:28:36
your B being a 1950 should have rollamaic. it is where the front wheels bolt on. the 2 arms that the hubs are mated with. well anyhow the decal goes on the front of the rollacmatic between the 2 bolt holes that are there.
if you have any other question about the decals feel free to email an i will try an help
johndeeregene
souNdguy
10-24-2003 21:35:03
 Re: Re: JD 'B' decals in reply to gene, 10-24-2003 21:28:36
Thanks.. I plan on doing some work on the B tomorrow.. so I'll check out that 'rolomatic' area and see if the original decal is there.. so far all the oem decals have survived to some extent .. it is just knowing where to look..etc.
Powertroll seemed hidden.. and If I had fenders.. might never have seen it.
Speaking of fenders.. did these B's or my year/sn come with fenders oem? or was this an 'option' / dealer equipment, etc.
If it was oem... are they available anywhere?
As for voulentering advice... that is a big job you just signed up for... I'm a JD newbie ( though i have lotsa fords... ).. so as I work on the refurb of this tractor.. there will be lotsa newbie questions...
Thanks
Soundguy
gene
10-25-2003 23:15:57
 Re: Re: Re: JD 'B' decals in reply to souNdguy, 10-24-2003 21:35:03
that is fine i glad to help you any way i can. as for the fenders they were a option that could order when you ordered your tractor right from the factory but then also any good dealer would have a set of fenders on the shelf. as to what type you should have is another thing i an not for sure which it should have beein that late of one. i cant remember if the clam shell fenders came out with the 50 an 60 series or if they came out when then went to a square axle on the A's. i think i will have to get the books an out do someresearch but i think your should have the round type that go over the fender
johndeeregene
souNdguy
10-26-2003 15:47:19
 Re: Re: Re: Re: JD 'B' decals in reply to gene , 10-25-2003 23:15:57
Thanks.
I saw a pic of a 39 the other day with the square fenders.. but then.. Not sure if those were oem either.
Also, I noticed that some of my decals.. are really metal plaques... And in great shape once I washed 50 years of dirt off.
thanks
p.s.
My manuals should be here monday I hope...
Soundguy
