burning points
johndeereman
05-04-2005 12:27:21
point gap is set right spark plug gap is set right but points keep burning the only thing is the points are 6 or 7 years old and not completely flat on my way to store to buy a new set is there anything else i should pick up
Jason Z in MO
05-05-2005 13:37:09
 Re: burning points in reply to johndeereman, 05-04-2005 12:27:21
The job of the condenser is to absorb the voltage discharge of the coil and prevent the points from arcing (burning).
Be sure to replace the condenser
F-I-T
05-04-2005 14:51:02
We were always told to check/replace the condenser if the points were burning as well. It"s a cheap maintenance item.
Frank
G/MAN
05-04-2005 13:38:44
Check your voltage to the coil with the ignition in the "run" position and the engine off. If there is no ballast resistor in the ignition wire and it's a 12-volt system, you'll get a full 12 volts to the coil, which will cut the life of the points way down.
ralph oregon
05-04-2005 12:37:38
get the one's with the vented hole it makes it work cooler. ralph
