148 vs 260 loader
Ed Meyers
05-04-2005 12:19:52
i have a 4320 and i know every body says 158 loaders fit them but i have seen some with 148's and i like the tight fit to the front of the tractor i also stumbled across a 260 that has a joystick but the brackets for a 2950 my question is could i modfiy them to fit my 4320 or should i try to find some for my tractor.
and what are the pro and cons of the 2 loaders.
David in MD
05-04-2005 13:56:23
 Re: 148 vs 260 loader in reply to Ed Meyers, 05-04-2005 12:19:52
I don"t know about the 260 loader but I"ve got a 148 on a 4230 which is a nice match. Dad had a 148 on a 4320 and the loader was pretty beat when he traded the rig off but so was the tractor. The loader had been on the tractor 24 plus years and was used for manure, dirt, grading, lifting, and as a bulldozer. The 158 would definitely stand up better to abuse from the 4320 but the 148 held up ok. 148 and 158 loaders are not that easy to put on or take off. Dad now has a 740 loader on a 7410 which is a quick attach, self leveling loader with greater lift and reach but the visibility and maneuverability is lousy.
Gerald J.
05-04-2005 21:39:20
 Re: 148 vs 260 loader in reply to David in MD, 05-04-2005 13:56:23
According to my manuals, which cover 148 and 158 in the same book, the major differences between the 148 and the 158 is reach. There may be larger steel in the 158 to give it enough strength with the longer leverage of the longer arms. I suspect its not stronger for bulldozing than the 148.
I know nothing of the 260.
Gerald J.
gpop
05-07-2005 19:02:47
 Re: 148 vs 260 loader in reply to Gerald J., 05-04-2005 21:39:20
got a nice 148 that we don;t use anymore if intrested give me a jiggle
swcol47
05-17-2005 10:19:53
 Re: 148 vs 260 loader in reply to gpop, 05-07-2005 19:02:47
Do you still the 148 loader? If so, where and how much?
playfarmer
05-11-2005 19:48:56
Hi Might be interested in your loader. Where are you located? Condition of loader and price. Thanks
Mike M
05-05-2005 06:44:23
The lift cylinder diameter is a little larger on the 158 than the 148.
Ed Meyers
05-05-2005 10:27:04
 Re: 148 vs 260 loader in reply to Mike M, 05-05-2005 06:44:23
dose any one know of a 148 for sale
JDBert
05-05-2005 14:56:22
 Re: 148 vs 260 loader in reply to Ed Meyers, 05-05-2005 10:27:04
for the money you'd be alot happier with the 158, alot more loader then the 148. I've got a 158 on my 4010, the 158 is rated for 150 horse or so tractors. When we bought it new the idea was a lower horse tractor to make sure we did not tear up the loader, it actually worked in reverse and we tend to tear the tractor up, broken spindles and hubs have not been uncommon.
