Hold everything right there...grinding the valvs a
buickanddeere
05-04-2005 11:37:06
If you are interested in having the engine start and run better after the rebuild than before? NO NOT grind the valves and seats. It doesn't look like much but do the math. You will drop the engine's compression ratio and no have a hard starting machine that runs less efficient. New seats and valves or forget it. This isn't a Dodge slant six gasser.
hogman_2002
05-04-2005 20:53:41
 Re: Hold everything right there...grinding the val in reply to buickanddeere, 05-04-2005 11:37:06
I have a tech manual for the 466, so I will make sure the valves have the right amount of "standout".
