Yesterday the rubbernecking, tree huggin, neighbor was over at the house. Having nothing to do, I suggested we have a look at his broken tractor. We had been avoiding it because he had no money to fix it (like several hundred bucks or who knows what)....course we didn't know what we were up against till we looked. So we did.Upon dismantling it we found the following: Just below the steering wheel is a nut assy that holds the wheel fixed in position vertically (supposed to). Upon twisting the wheel, with the shaft locked vertically, the twisting motion causes the steering box to move up or down the big screw that's on the lower end of the steering wheel shaft, which moves the steering arm connected to the drag links back and forth, which steers the front wheels (supposed to). The long black cast iron housing that encircles the shaft, and bolts to the tractor's housing, had completely sheared at this nut during the impact with the tree....I mean straight across like you were cutting salami with a knife. This voided the vertical restraint and allowed the shaft to rotate upwards when the wheel was turned (either right or left...can't remember) and exit the top of the box. Well, the box is full of ball bearings (loose). When the screw comes out the top (cause you turned the wheel), the balls fall out the bottom and you loose the connection between the shaft and the box; hence absolutely no steering. Sooooo o. Looks like the fix is a no brainer. Weld up the cast housing, collect all the balls (we did) and put the balls back in the box.....that's a little tricky, but have been there before on this tractor and it's not that bad once you understand it. Remount the assy to the tractor and you're done. Anticipate the cost to repair at $40 (for welding). I would have welded it for free, but have no experience with cast iron and we want this done once, and right the first time. Not bad, and this guy, of limited means, will have his tractor back and he is surely excited about that..... just in time for hayin season. Mark
