Boys Throw away those WICO XB and get a Delco
wilamayb
05-03-2005 19:57:51
I recently replaced my Wico XB with a Delco on my late B. It makes an unmeasureable amount of difference. I used to have a terrible starting problem. I thought it was I had a hot blue spark across a 3/16 gap plug. The delco fixed it all. It no longer starts hard. It dosent flutter under heavy load, and it is considerably stronger. My suggestion is if you have an XB just throw it away (nobody will buy it) and get a Delco. It will save you lots of headaches.
Kurt_JDB
05-04-2005 19:21:28
 Re: Boys Throw away those WICO XB and get a Delco in reply to wilamayb, 05-03-2005 19:57:51
I would be happy to take these unwanted XB"s off your hands.. Will pay shipping plus 10% of whatever your Delco cost you.
Kurt
wilamayb
05-05-2005 05:37:36
 Re: Boys Throw away those WICO XB and get a Delco in reply to Kurt_JDB, 05-04-2005 19:21:28
I,ve got 65 dollars worth of new parts in it , so I will need more than 10% of my delco. I want at least $35.00 It has a new cap, rotor, points and condensor. They are all deere parts not aftermarket. If you want it email me at [email protected]
Mike M
05-04-2005 06:13:08
AMEN ! I second that !
Lee B
05-03-2005 23:32:42
What model Delco fits your B? Was that a long lug or short? I've got an early styled B that calls for the long lug is why I'm asking, need to know what to ask for after all.
730-LP
05-04-2005 17:25:42
 Re: Boys Throw away those WICO XB and get a Delco in reply to Lee B, 05-03-2005 23:32:42
Lee you can take a short lug dist. and remove the piece that has the lugs and weld a piece of key stock on it.3/8? I think.
Mike M
05-04-2005 06:19:07
I don't think they made one that will fit a tractor that takes a long lug mag. You may be better off with a good Wico XH series mag. If you must have a delco dist. you could probabaly change the part on your governer that drives the mag. and use one from a later B.
