6030Tom
Tom (Ks)
05-03-2005 19:06:51
What all did you find with the tranny on the 6030??? Did you just get the tractor?
6030Tom
05-04-2005 18:59:53
 Re: 6030Tom in reply to Tom (Ks), 05-03-2005 19:06:51
I just got it towards the end of last year. Went out your way (KS) to pick it up. No one but you responded. (thanks) I've heard else where that some people would weld it on cause 6th was such a well used gear especially when the fuel was turned up the key holdin the gear to the shaft couldn't take the power. True of false I do not know ,that's just what I've heard. I don't believe that that gear is used in 5th or 7th. are you familiar with this type of situation?
Tom (Ks)
05-05-2005 17:40:12
 Re: 6030Tom in reply to 6030Tom, 05-04-2005 18:59:53
Sixth gear is a little fast in 6030's, most people use it to down driveways and then shift into eight. I havent seen anyone weld up any gears in that tractor, but I have seen that gear come off a 4430 two times (he had a dozer blade on it), sixth and eighth gear would knock the snap ring off and slide back and grind against the other gears. I think in your case someone junked it toghter enough to sell. Sorry to tell you that. What part of the state did you get it??
6030Tom
05-06-2005 04:27:38
 Re: 6030Tom in reply to Tom (Ks), 05-05-2005 17:40:12
Wichita area. That certainly is a possibility. Pushing the snap ring off. Maybe that is why the weld is on there, they got tired of replacing the snap ring So they put a weld on it in stead to hold it in place. It could be junked too, just need to get it out an test it out. I learned what to look at and for when buying a tractor....after bringing it home.
Tom (Ks)
05-06-2005 17:45:53
 Re: 6030Tom in reply to 6030Tom, 05-06-2005 04:27:38
If all they did was weld the snap ring on, then that wouldnt be too bad. I thought they welded the teeth back on the gear or something like that. Good luck with it, 5020's, 5010's and 6030's are real tractors!!!
