spark plug help!
Paul.D.Canada
02-22-2004 17:24:47
Could someone explain the heat range of spark plugs to me?I am going to buy new plugs for my 48 "D" and need to understand the heat range thing before I buy. I will be using the tractor for pulling a few loads of hay, 2 or 3 parades and 2 or 3 local antique pulls(not any real competition,just for fun).Right now it has Champion W-18's in it(just in the process of getting it running so not sure yet how it runs with those!).Any help would be appriciated and thanks in advance Paul.
buickanddeere
02-23-2004 13:13:02
 Re: spark plug help! in reply to Paul.D.Canada, 02-22-2004 17:24:47
Paul will she be running on gasoline, kerosene or #1 diesel? If the Champion plug has a "R" for resistorin it's part #, better to avoid them in JD two cylinders. Haven't looked at the "tinker fixed" 820 yet. Have to wait until the income tax refund comes back. Wife wants a swimming pool installed this year too..... .... sigh.
Duane Larson
02-22-2004 20:14:47
Paul,
Clooney and John T. have covered the topic of heat range very well. About all I would add is your D came with Champion 2ComL 2-piece take-apart plugs. I run those in my old tractors as it makes cleaning a breeze - just unscrew the gland nut, pull the center electrode out, clean it off with your favorite cleaner (except abrasive blasting), and reassemble. I have been running the same sets of plugs for years.
If you use a modern plug, put in the hottest plug you can find for your described use. I can't remember pulling a 2-cylinder plug in the last 20 years and thinking they needed a colder plug. The W95D Champion would fill that order, but make sure there is proper clearance in your engine as it has a long reach.
If you are interested, Don McKinsey normally has 2ComL plugs, write him at P. O. Box 94, Wilkinson, IN 46186. They are about $12-15 apiece now, but worth it in my book. As with most old things, they don't make 'em anymore.
Paul.D.Canada
02-23-2004 14:36:33
 Re: Re: spark plug help! in reply to Duane Larson, 02-22-2004 20:14:47
Duane,I found two of these 2comL plugs in the tool box of this tractor. They appear to be in good condition with very little wear on the centre electrode and have two bars going to the centre electrode (is this normal ?). What type of cleaner do you recommend? And is there any tricks on taking them apart? Thanks again Paul.
Duane Larson
02-23-2004 17:29:46
 Re: Re: Re: spark plug help! in reply to Paul.D.Canada, 02-23-2004 14:36:33
Paul,
Sounds like they are worth a try. Yes, two ground straps are proper on the 2ComL plug. To disassemble, hold the hex shell of the plug in a vise (not too tight), and take a 13/16 deep socket to loosen the bushing. (Don't hold the bushing in a vise as it is thin and easily deformed). Pull the center electrode and sealing washer out of the shell. Use carb cleaner and some non-scratching pad (ask your wife for something) and clean the porcelain you removed. You don't want to scratch the porcelain. You can bead blast the shell with the porcelain removed, or use a wire brush or whatever to clean the shell and ground straps. Then reassemble with the sealing washer in place, and tighten the bushing to about 20 ft lbs. Use a new crush washer between the plug and head. I use a bit of gun bluing on the shell and bushing, and the plug looks like new.
If you have a good magneto, open the gaps up to 0.040 or so (I run mine at 0.050) to improve the idle.
Paul.D.Canada
02-24-2004 15:37:00
 Re: Re: Re: Re: spark plug help! in reply to Duane Larson, 02-23-2004 17:29:46
Duane, thank you for your help I'm going to try this tonight.Paul.
John T
02-22-2004 18:45:15
Paul, the "Heat Range" of a plug has to do with its thermal characteristics, NOT anything to do with the electrical spark. The hotter the rating, the physically hotter it runs and perhaps better burn off potentially fouling deposits such as excess unburned fuel or oil deposits. The firign tip is out in the combustion chamber and a hotter plug dissipates heat away less than a cooler plug. i.e., it runs hotter. On light use tractors, I ALWAYS RECOMMEND a heat range or two hotter than the factory spec. Those old tractors were designed to operate under load and at RPM in which case there was less unburned fuel and oil deposits left remaining on hotter running plugs. If we work them at small loads and dont get them up to temperature, the plugs dont run as hot as designed for and potential fouling deposits may accumulate on them, which is why I recommend hotter than original plugs. I like the hotter side wire Autolite 3077 where the specs call for say the 3076.
Post back or e mail me at [email protected] if you want a more detailed and physics/engineering discussion of plugs or call me at 812-824-4608.
Good Luck n God Bless ya Paul
John T
old
02-22-2004 18:22:17
Clooney has told you right Paul for what you want to do a W-20 will probably do you good. I need to get a couple for my B since it has fouled out one, but all it has done since I got it running is drove around the yard a few times. In the next few day I get to try to get a Farmall up and running so I can get it home, its parked where if it doen't run it will not get home, but only payed $300 for it.
Paul.D.Canada
02-22-2004 18:30:17
 Re: Re: spark plug help! in reply to old, 02-22-2004 18:22:17
Old, I wish I could find some old tractors up here in Canada for that price!!Thanks again Paul.
old
02-22-2004 18:56:40
 Re: Re: Re: spark plug help! in reply to Paul.D.Canada, 02-22-2004 18:30:17
Well a friend found it, he figures with what I know about tractors and the fact he has a pawn shop that we could make some money with him finding them and me fixing them up. But I'm not sure I want to get it to it that much, I like to play with them but if he finds to many it might get to be to much like work and I'm retired so I just like to play with them.
Also my wife is worryed it might get to be to much for me since I am disabled I guess time will tell. Also I have unblocked my e-mail so if you want to ask more questions you can e-mail me.
Clooney
02-22-2004 17:53:47
Paul, the heat range on a spark plug is it's basic ability to carry heat away from the center electrode of the plug to the plug's base & then to the iron that the plug is screwed into.. Usually the hotter the plug the farther the distance between the center electrode & the plug case so the heat has to travel farther.
~Different plugs use different numbers to signify the heat range so you can't directly compare numbers between different brands of plugs..
On the W-18 Champion's you have in your D? The higher the number the hotter the plug.. The hotter the plug the hotter the center electrode operates at to burn off fuel & oil residue.. If the plug is too hot it can glow red hot & cause preignition or burn the plug electrodes prematurely.. A hot plug is better for light usage & idling.. A colder plug is used for extensive hard work or continuous loads like plowing]..
~On those W-18 plugs the W is the thread size [on the W-18 that's 7/8"].. The 18 is the plugs heat range.. There is a W-14 [real cold],, a W-16Y [just a little colder],, your W-18 [normal] ,, then the W-20 [hotter plug],, or W89D [real hot]
~Probably the Champion W-20 would be a good choice for the way you want to use your D..
~If you don't like Champions {I don't personally have any problems with them} you could also use Autolite 3076 [close to your W-18] or Autolite 3077 [cross to Champion W-89]..
Hopefully Duane Larson will answer here as he is a spark plug expert..
[email protected]
