730 D Electric
Scotty
05-03-2005 17:47:27
I have a 730D that I'm trying to bring back to life and get it cranking but I am not sure how to get it cranking. I have taken the hood, side grills and fuel tank off to clean things up and replace the wiring. I've also taken the dash off and this is why I can't get it cranking . All the switches and guages are shot and are going to be replaced. I am trying to figure out how to get the starter cranking without any of the switches. Can I cross something at the starter to get the starter turning ? It's a 24 volt system with 2 twelve volt batteries in stead of 4 six volts. Thanks for your time and help. Scotty
Doug_Eshler
05-04-2005 17:06:35
 Re: 730 D Electric in reply to Scotty, 05-03-2005 17:47:27
This is a trick I've used. Take another two cylinder and line the belt pulleys up. Then get a belt like they used to use on a hammermill and put a half a twist in it. Tighten up the belt and disengage the clutch in the 730 and engage it in the other one. Get it spinning and then engage the clutch in the 730. That will get it spinning good so you can see where you got fuel or any smoke.
Scotty
05-04-2005 17:31:33
 Re: 730 D Electric in reply to Doug_Eshler, 05-04-2005 17:06:35
Hey Doug, that's pretty slick! I'm going to try that, thanks
Scotty
mike brown
05-04-2005 05:48:28
Better invest in a manual, John Deere shop is better than IT manual.
There has to be a way to make it spin with jumper cables. I can tell better when I get home tonight. Make sure it is out of gear and make the connection on the tractor not the batteries, there are likly to be a lot of sparks.
Good luck returning that tractor to it's original split polarity system. If it was mine I would try the series/
parallel switch to provide the 24V to the starter.
Scotty
05-04-2005 16:49:24
 Re: 730 D Electric Starts in reply to mike brown, 05-04-2005 05:48:28
Thanks Mike, I'll bring a manual home tonight but it's for a 720, I think they are pretty close or maybe the same as a 730. That's the only John Deere manual i can get . I have a IT manual but it ain't much help. I think I have 24 volts at the starter but I'm not real sure how to check it because isn't it postive ground ? I have to 12 volt batteries, one battery is hooked to the other with a cable going from negitive on one battery to positive on the other battery, on the other end of the batteries the positive goes to the big post on the right side of the solenoid, the other cable witch is negitive goes to a post that sticks out the side of the starter. The solenoid also has a spade termnial under each big post. shouldn't this be 24 volts ? Thanks for your time and help. Scotty
buickanddeere
05-05-2005 00:34:40
 Re: 730 D Electric Starts in reply to Scotty , 05-04-2005 16:49:24
Is there a line to chassis from the middle point where the two 12V batteries join?
Scotty
05-05-2005 15:04:47
 Re: 730 D Electric Starts in reply to buickanddeere, 05-05-2005 00:34:40
No, the cable that joins the to batteries together are hooked with one cable comming from the postive side of one battery and the other end of that cable is hooked to the other battery to the negitive side but that one cable does not have a chassis ground hooked to it. Should it be ? The other end of the battery , positive side goes to the right side big post on the solenoid and the negitive goes to a post that sticks out the side of the starter. Thanks for your help...Scotty
