2210 PTO catastrophic failure!!!
Bill in Orono,
05-03-2005 17:16:17
Hello,
Well the lakes finally thawed as did the ground. So I pulled out my Woods tiller, hooked it up and went tilling. By the way, the 60" GTC tiller works great behind the 2210--or it did.
I was tilling about, occasionally finding a rock, a brick, 10" of chain etc, but all was going good until WHACK. Buzzzzz zzz. While the Tiller now still turned it was accompanied by a gear clashing noise. I limp to the garage, disconnect the tiller and notice the PTO shaft it now 15 degrees of so off kilter and the PTO shift lever is now stuck. Holy Hand Grenades!
Any one heard of or had this happen to them. I was figuring that the combination of a slip clutch, shear pins and japanese engineering would be all one would need. Now I sit on pins and needles waiting to see if this is a warranted incident or not. Dealer was of the though that it probably was but....
As misery loves company my 2210 was the second 2210 to show up at the dealer today with the same PTO difficulties. Also from rototilling.
Patrick Cohrs
07-12-2005 13:12:43
 Re: 2210 PTO catastrophic failure!!! in reply to Bill in Orono, MN, 05-03-2005 17:16:17
Yes! I had the same thing just happen to me. My 2210 just 30 hours on it. My three neighbors also have 2210's I was told if you buy one we can all share the implements one of course a john deere tiller all happy (not so). I used it for about a hour or so worked fine and yes hit a rock or two. when I heard a louder noise tilling and slipping shut the pto down. removed the tiller. yes the pto shaft was off center and leaking oil. I was told by the John Deere dealer that it was the the tiller pto shaft was to long and caused a axial load that caused the failure? I worked in a motor shop for 20 years worked on large gearboxes and I know when there is a axial load failure it would be the edge of the gear not the whole gear. I know this failure is just plain as day (gear failure) further more my friends tiller spline shaft did not bottom out there was plenty of room for shafts to grow! I was also told John Deere might not pay for this! I thing if John Deere makes a tractor with a (PTO) it should be able to handle a John Deere Tiller and I was told it would! Anyone agree with Me on this? I will fight this with your help together.
Pamela Donnelly
07-21-2006 19:15:44
 Re: 2210 PTO catastrophic failure!!! in reply to Patrick Cohrs, 07-12-2005 13:12:43
I have a 2210 tractor that had a "Catastrophic PTO Failure" at about 116 hours. We were also using the John Deere tiller. The day before the failure the engine started idling funny up and down in RPM. My husband uses the machine to till manure (no rocks). The next day I took the tractor over to our recently hand tilled lawn to get some deeper tilling but the blades of the tiller only hit the very surface of the lawn. It even stalled at one point. I went to get my husband to let him know I was having trouble and he took the tractor and ran the tiller in our empty field (again no rocks). It didn't appear to be doing anything but brushing the surface. My; husband lifted up the tiller while it was turning to see if anything was obvious and there was a definite pitch change. He turned off the PTO and turned off the tractor. We walked to the back and there was hydraulic fluid pouring out on to the field. When the service person came to pick the tractor up he informed us that the PTO was cracked. I just got off the phone with the service supervisor after they had gone through the tractor for two weeks (apparently they had to wait for the John Deere representative to come look at the tractor before they could touch it). He informed me that the PTO is cracked, there is a hole in the tiller gear box, there is transmission problems, etc. We are looking at over $4K in repair. The supervisor said that John Deere probably wouldn't pay for it. He said that in there opinion, it appeared that we had run over a rock while tilling on a turn. I am furious. The hardest thing that tiller has seen is manure. Something appears to be wrong with the design and it appears that quite a few people have experienced something similar. Please let me know how everyone else resolved the warrantee issue, if at all.
Frank in SC
07-13-2005 13:32:16
Sounds like our experiences are very similar. I am supposed to pick up my repaired tractor in the next day or so. So far, it looks like it will not be covered by the warranty. Have you contacted John Deere customer service at 1-800-537-8233? If you do or have tried, please let me know your experience so we can see if it's similar to mine. I even asked to speak to a supervisor which was a waste of phone time. They just referred me back to the dealer and said that the dealer was their agent.
Frank in SC
07-11-2005 16:13:36
Bill in MN:
Hi. No, you are not alone in regards to your tractor's PTO failure. My 35-hour-old 2210 evidently was not designed to do more than light duty work. While cutting grass using a TM5 finish mower, I scrubbed across a 2 inch pine stump-not a fresh cut-but a 4-year-old stump.
Sounding like I hit barbed wire, I stopped the tractor, lifted the cutter and checked to see what happened. Not seeing anything tangled, I noticed fluid leaking from the PTO shaft seal.
After taking the tractor to the dealer for repair, I was informed that the damage was considered "abuse"!! To add insult to injury, that abuse will cost approximately $4,300.00 to repair. "NOT WARRENTEED."
Contacting John Deere's customer service only resulted more frustration.
Please let me know how you came out dealing with warranty service and if you've had any more problems with the tractor.
Lou in Massachusetts
05-16-2005 05:36:50
Bill in MN:
I was referred to your post by a person who apparently surfs this forom and another tractor forum in which I circulate. I posted a similar story on that other forum, although my situation does not appear to have been nearly as catastrophic. I used a rented tiller last week (5/12/05) and noticed only after I was finished and removed the coupling that my rear PTO shaft (on a model 2210) was off axis by about 1 or 2 degrees. In fact, I had to clean it off and really study it in motion before I confirmed that it is definitely off axis. Only in retrospect to I recall hitting a couple real rought spots and some rocks. On one ocassion the tractor did shut down (bad sign), but I looked around and at the shafts and couplings and did not notice anthing then so I continued. In retrospect, the point of tractor shut down is probably when this occured.
In ant event, do you now know whether your warranty will cover? Also, in either case, do you know the approximate dollar value in damage to your tractor? Any info is appreciated as I am about to embark of getting this taken care of. I will also let you know how I made out. Thank you.
Mike M
05-04-2005 06:05:57
They may very well have a weakness as everything is cheaply made anymore. I think a 60" tiller is too big for it and JD's warranty claims people may also ? Those slip clutches tend to rust fast from sitting and before every use you are to loosen up the adjustment bolts and make it slip so you know it works,then tighten it up just enough so it doesn't slip under normal loads.
