Governor spring moves throttle lever
DeereDave
05-03-2005 13:43:50
When I move the throttle lever all the way forward and release my hand from it, the spring on the governor (at least I think that's what's doing it) moves it back some so it won't stay wide open. The governor has two springs on it. Should the rod that comes from the throttle lever be attached to the inside spring (closet to the governor)or to the outside spring? Thanks for any ideas.
John Van Valkenburgh
05-03-2005 16:30:45
 Re: Governor spring moves throttle lever in reply to DeereDave, 05-03-2005 13:43:50
Dave,
Generally speaking (at least with the model B and 50) there is only one spring at the governor. This spring sometimes gets weak over the years and to compensate some people add a second spring to boost it. You can still get the original spring from John Deere if you want it.
The throttle lever on the 50 is located on the right hand side of the steering column. It has a pair of internal "friction disks" that are pressed together with a spring and bolt. You reach inside behind the throttle lever and tighten this bolt to increase the spring tension on the friction disks. Over the years these disks wear out. You can get new ones from John Deere, or as many people do, you can make your own out of a piece of leather. I used a pair of cutting wheel disks that I trimmed down to size and notched out inside to duplicate the original disks. They have been working fine now for a couple of years.
Hope this helps,
John
1953 Model 50
Bob
05-03-2005 14:53:55
What tractor? It sounds like you may need to tighten up the spring pressure on your throttle lever friction pad (or taper) or replace the friction pad, (if so equipped).
