4230 SYNCHRO
JIMDD
05-03-2005 11:42:01
Does anybody have any pros or cons on this tractor w/this trans. Is there any bad points about it? I'm looking at one and don't know much about it
David in MD
05-04-2005 14:14:53
 Re: 4230 SYNCHRO in reply to JIMDD, 05-03-2005 11:42:01
I've got a 4230 with quad range which is nice. I've used 4320, 4020, and 4010, and 3010 all with synchro trans which were just fine. I prefer the quad range but would buy a synchro if it was in good condition and in my price range. The 4230 is one of the worst cold starting tractors JD has ever made. JD does make a 12 volt heated intake manifold that is supposed to help but I've been reluctant to spend $600 without finding someone who tried it first. The only response I ever got from this board was that if it didn't start well I needed to rebuild the engine and injection pump, and replace the injectors, starter, batteries, and cables. Once started this tractor runs as well as any.
Cory R.
05-04-2005 06:10:40
It Should be a good tractor my uncle has the original my grandpa bought brand new. it a 1974 quadrange 4230 and it served as his farms big tractor until a few years ago when he bought a 3155 john deere with 4 wheel drive. only bad thing is that the tractor is hard starting you have to use either on him when it like 50 degrees or just plug the block heater in for like ten minutes and he pops right off. over all a great tractor and i recomend you buy it.
stum
05-03-2005 16:56:58
4230 is a good all around chore tractor,but noted for hard starting when cold. The synchro is a good trans,pretty much the same as the synchro in a 4020,but with the advantage of the permaclutch(clutch runs in oil). The synchro option tends to lower the value of the tractors compared to the quads and powershifts though.
gordon hulgan
05-03-2005 15:45:44
hi jimdd.they are top off the line 4230,4220 and the price go up every day. check ebay out today. real nice 4230.
mike brown
05-03-2005 16:53:24
 Re: 4230 SYNCHRO in reply to gordon hulgan, 05-03-2005 15:45:44
I have a 4230 with the quadrange. I think the sycro is a bit less user friendly since it has no hi-lo range. I think it is a reliable transmission though. It should be a bit cheaper than a quad or powershift to buy.
That series tractor is notorious for needing a snort of ether to get started. Mine needs ether if it is cool enough to wear a long sleeve shirt. It runs fine though and has a lot of power. When you go look at it try to start it with out ether first but don't be alarmed if it needs a snort.
