620 Gas in Oil
Greenguy
05-03-2005 11:28:39
Have a 620 JD and the motor kept backfiring and then died. Smells like there could be gas in the crankcase. Had been running ok.
What could have happened? Draining the oil right now ... Thanks for any help Greenguy
dads730
05-03-2005 15:35:03
 Re: 620 Gas in Oil in reply to Greenguy, 05-03-2005 11:28:39
I would be willing to bet you have the automatic fuel shutoff on your sediment bowl. If you have not replaced the two rubber diaphrams in that shutoff system they will go bad occasionally and allow the fuel to go straight into crankcase. The fuel now days ruins them frequently. Rebuild that shutoff and should fix the problem.
Glen Anderson
05-03-2005 14:12:38
I'm not familiar with the 620 but if the fuel level in the float bowl is too high due to a faulty float, needle, seat, or maybe even just adjustment, it will cause the engine flood and possibly backfire. Also, if your 620 is equipped with a diaphram type fuel transfer pump as opposed to gravity feed, the fuel pump is most likely the source of the contaminated oil. The diaphram will deteriorate over time and allow fuel to enter the crankcase, the fuel pump output will suffer and may cause the engine to run lean also causing backfiring.
Hope this helps.
105Diesel
05-03-2005 15:50:15
 Re: 620 Gas in Oil in reply to Glen Anderson, 05-03-2005 14:12:38
I"d really like to know how you figure that the 620 tractor has a fuel pump.
Glen Anderson
05-03-2005 16:09:46
 Re: 620 Gas in Oil in reply to 105Diesel, 05-03-2005 15:50:15
As I said at the start of my first post "I'm not familiar with the 620", that is also why I said "if your 620 is equipped with a diaphram type fuel transfer pump as opposed to gravity feed"
I might be mistaken, but I don't see anywhere that I've said "the 620 has a fuel pump".
105Diesel
05-03-2005 16:29:14
 Re: 620 Gas in Oil in reply to Glen Anderson, 05-03-2005 16:09:46
Quote: "Also, if your 620 is equipped with a diaphram type fuel transfer pump as opposed to gravity feed, the fuel pump is most likely the source of the contaminated oil. The diaphram will deteriorate over time and allow fuel to enter the crankcase, the fuel pump output will suffer and may cause the engine to run lean also causing backfiring."
How many times do you see "fuel pump" in what you wrote above?
Glen Anderson
05-03-2005 17:20:11
 Re: 620 Gas in Oil in reply to 105Diesel, 05-03-2005 16:29:14
I said "IF your 620 is equipped a diaphram type fuel pump as opposed to gravity feed", maybe for the benifit of people like you I should have said is: I'm not familiar with the fuel system of the 620 but If it is equipped with a diaphram fuel pump as opposed to gravity feed, please heed the following information, if not please disregard.
If you happen to be familiar with the 620 you should be offering advice to the fellow who is having trouble with his tractor rather than trying to make a point to me that the tractor in question doesn't have a fuel pump, even though I never said that that it did!
If you weren't able to understand what was written, that is one thing, however if you've got an axe to grind, do it somewhere else with someone else!
