JD 50 smoking a little
Tye
02-22-2004 16:43:42
Plowed a little today with the 50 and noticed that under load it smoked a little out the breather tube. I know it has good compression- did a comp. test last summer. It was enough smoke to notice from the drivers seat. I thought the clutch was burning for a second. Should I be worried about it? This tractor hasn't had a overhual since I've had it (20 years) It runs well with good power. Actually plowed a little in 4th gear with bottoms about 4-5 inches deep. Thanks for any help or input. Have a great day. --Tye
John Van Valkenburgh
02-23-2004 15:53:01
 Re: JD 50 smoking a little in reply to Tye, 02-22-2004 16:43:42
Tye, My 1953 model 50 will do the same thing once it gets up to temp and is running hard. Its venting out of the crankcase. Should be mostly moisture that has condensed in the crankcase over time. Might be a little worse if you are in need of an oil change. If you've got good compression, power, oil pressure and are not using a lot of engine oil then I would not worry about it. Good luck with the 50, they are great tractors. John
Ron
02-22-2004 19:12:56
Maybe you are just getting it up to a good operting temp, and are driving the moisture out of it.... Keep it hot for a good while, and it may quit smoking..
James
02-22-2004 17:31:27
Tye ,what you have is blowby from the crankcase . The oil vapors get hot when under a load for a while and is more noticible. There may be some things you can check such as the main bearing drain but not much if you don't plan on an overhaul. Watch the oil ,make sure it doesnt get too low . You may also try some heavier wt. oil in it . These things are old and well worn but you got to call the shots . Keep on plowing
