Front rim/tire for 2010
wirehair
05-02-2005 10:37:44
Folks,
I need to replace a front rim/tire on my loader tractor.
I was doing some box blade work around mewly planted tree seedlings (makes for smoother mowing this season) when the front right corner collapsed and the tire/rim went rollin' down the line independent of the tractor. After I corraled the errant runaway and examined it I saw that a metal of the rim ripped apart and tore off the spindle. Fortunately no damage to the spindle or any of the mounting bolts.
A call to JD dealer produced price estimate of about $75 for replacement rim, but they said that their 'puter does not show 6x14 as an option for this tractor. My independent mecahnic tells me that I should be runnig 15 or 16 inch rims with at least 8 ply tires. Current tires are 6 ply.
So, it looks like I may need to get both sides replaced. Any suggestions on a good source to buy this from ?
I got a lot of work for this old girl, so need to get it put back together.
Thank you, wirehair
AndrewD
05-02-2005 17:56:00
 Re: Front rim/tire for 2010 in reply to wirehair, 05-02-2005 10:37:44
the 6x14 was the smallest size offered for the 2010r. the book i read shows the 6x14 for the 2010r only. my 2010r came with them and i have 2 extra 6x14 rims if u need one. email is [email protected]
AndrewD
Gerald J.
05-02-2005 10:51:47
I'd go with wide implement tires on wide rims. Be sure the rim load rating is as great as the tires, else you could break out the center again.
On my MF-135 with loader I went to 11L-16 on 8" wide rims and that made steering a lot better and the wide tires didn't cut ruts in soft or wet ground nearly so bad. When I moved that loader to my 4020, I moved the rims and tires too, but found the smooth implement tires didn't steer well while rotary hoeing, so I went to a bigger 11.00-16 (too big for the 1010) 4 rib tire, still on the 8" wide rims.
9.5L or 11L 15 or 16 would be nice tires for your loader tractor. The 11L need an 8" wide rim. The 9.5L tires would like 7" wide rims.
Good front tires will set you back nearly $100 each and rims at least $60 each unless you find them used. Then be sure they have adquate load rating to keep them from breaking.
Gerald J.
Bob
05-02-2005 10:42:46
Check at a local farm tire dealer. They usually have sources for rims.
