A POWERBLOCK
JERRYD
05-02-2005 06:08:23
Just acquired a 51 A from an elderly gentleman and started tinkering with it yesterday when I noticed on top of the block it says powerblock-3" I guess I've heard of them but does anybody have andy insight of why they were used adn if good or bad. thanks
Quilly
05-02-2005 21:35:10
 Re: A POWERBLOCK in reply to JERRYD, 05-02-2005 06:08:23
Be very carefull if you start to rebuild your A with the powerblock. There are a lot of powerblocks out there advertised with "chipped" sleeves. This comes from letting the rods drop against the back of the jugs. Stuffing rags in the back of the block before removal works great. Just dont let the rods drop and you will be alright.
JDVan
05-02-2005 11:17:50
I have one of these also not presently installed on a tractor. These blocks were sold by TSC in the late 50"s and 60"s to increase HP on the late A"s and early 60"s. The bore size is 6-1/2" as opposed to the standard 6" and also increase the compression a bit. 10 to 20% increase in HP was advertised. These blocks are wet sleeved and the sleeves come in from the bottom. There is a ring at the top of the sleeve that increase the compression with Power Block compatible aluminum pistons. The pistons have to be removed from the bottom not the top. Standard rods can be used, either babbit or insert bearing types. The extra compression and HP makes these a bit harder on the rod bearings and piston pins and I have been told that the sleeves are not as hard as a normal conventional JD Block cylinder walls causing wear out to occur a bit faster. Also I have been told that even when new these TSC blocks had some problems with the sleeve "O" rings leaking occasionally. I have not found any company that makes the "Power Block" sleeves as a standard product but there are comapany"s that will make replacement sleeves on a custom basis. $$$$$. I have talked to those with experience that say the increase in HP is very noticeable.
Others have bored the existing TSC sleeves and then lined the original TSC sleeves to get back to the standard TSC piston size as an alternate to getting custom replacement sleeves made.
These blocks are very much in demand by competitive pullers.
gwh
05-02-2005 12:12:19
  A-60 bore size! in reply to JDVan, 05-02-2005 11:17:50
I think you will find the standard bore of the A and 60 is 5.5" with the "power block" bore increased to 6"
JDVan
05-02-2005 12:18:37
 Re: A-60 bore size! in reply to gwh, 05-02-2005 12:12:19
Ooops. You are correct. Too many different tractors here. Sorry for the error. I should have stood in bed this morning.
