4020 PS Question
JG
05-01-2005 19:58:10
I recently acquired a 71 4020 with a PS transmission. When I let out the inching pedal in 6th gear or above, the tractor moves at a slower speed and then will speed up to what seems like the proper speed. When I shift without the inching pedal, it shifts properly. Any ideas? Also, there is a yellow button on the left side where the hydrolic pump release lever would be. Does this button do the same thing as the lever? Any help would be appreciated.
Thank You
msb
05-01-2005 21:13:51
 Re: 4020 PS Question in reply to JG, 05-01-2005 19:58:10
The situation you describe is normal when using the inching pedal Nothing to worry about, but I would start in a lower gear than sixth then shift after the tractor is moving.
Hydraulic pump release lever? You mean the clutch disconnect lever?If the button is on the dash,it sounds like it is a horn button.Or is it a knob that releases the lever when it is pulled back?I forgot about the set ups on those late model 4020 Power Shifts.
